Captain Malachi Posted November 29, 2008 Share Posted November 29, 2008 I plan to include an inquisitor lady in my daemonhunter force, and the plan is convert a sister superior, specifially this one. The problem is that I intend to give her a psycannon, but the only place I seem to be able to get one is on the terminator bitz pack, which doesn't seem like it will be a very good fit, so have any of you got any ideas on how to solve this little problem of mine? :o Link to comment https://bolterandchainsword.com/topic/153591-in-need-of-some-help/ Share on other sites More sharing options...
Inquisitor Agrippa Posted November 30, 2008 Share Posted November 30, 2008 Seeing how (to my recollection anyway) the only easy to use psycannon for conversion is that Termy one, the only other option then is to try and scratch build one. I've used that sister model myself for an elite Inquisitor and made just a simple swap of her bolter for a combi-weapon. She's not in the best pose per say for much conversion without a lot of work. I've seen the termy psycannon arm adjusted to fit the body of the Cotez model. So it would be possible, though with work, to get it to fit her but I do believe you might be right in the size difference. Link to comment https://bolterandchainsword.com/topic/153591-in-need-of-some-help/#findComment-1790351 Share on other sites More sharing options...
Marid Posted November 30, 2008 Share Posted November 30, 2008 Scratch build is probably the way to go with that SOB. Use green stuff and build it up over the bolter like I did with my inquisitor. This was my first green stuff conversion, so it wasn't difficult: http://web.pdx.edu/~wordr/Photos/Warhammer40k/inquisitor_with_psycannon_small.jpg Link to comment https://bolterandchainsword.com/topic/153591-in-need-of-some-help/#findComment-1790430 Share on other sites More sharing options...
Aidoneus Posted November 30, 2008 Share Posted November 30, 2008 I also converted a psycannon-toting Daemonhunter inquisitor from a WH model. I used the Hereticus Inquisitor Lord model (with the Van Helsing hat). For the psycannon, I took 2 IG Grenade Launchers. I stuck the two drums together, and lobbed a bit off the barrel. I then added a few wires out the back, made from paper clips and guitar wire. Here are a vew pictures of my Inquisitor, Konrad von Marburg. Front Side Back Link to comment https://bolterandchainsword.com/topic/153591-in-need-of-some-help/#findComment-1790483 Share on other sites More sharing options...
Tauren Posted November 30, 2008 Share Posted November 30, 2008 Honestly, psycannons are 2 handed weapons. That said there are variations. For example there is such thing as a shoulder mounted smaller version of said psycannon. I suggest you just convert their gun to look unique. For instance with my inquisitor I just chopped off the bolt pistol end and attached an oversized barrel to the front and vents to the side of the gun to represent the increased coolant needs of a heavy weapon. Mine looks like a custom "dirty hairy style" oversized long barreled pistol. Link to comment https://bolterandchainsword.com/topic/153591-in-need-of-some-help/#findComment-1790491 Share on other sites More sharing options...
Captain Malachi Posted November 30, 2008 Author Share Posted November 30, 2008 Thanks guys, think I'll go with Marids idea, seems the easiest and I need all the practice I can get with green stuff anyway, plus the gal has a handy bolter already :devil: Link to comment https://bolterandchainsword.com/topic/153591-in-need-of-some-help/#findComment-1790641 Share on other sites More sharing options...
