Relictors Blog
Mol,
The only thing I see is that I think the bandolier would look better flipped so that the percussion caps on the bolts were on top, rather than hanging out the bottom. Otherwise, looks good.
-T.
I was trying to remain faithful to your artwork - I couldn't tell which way round you'd put them. I'm back in Leicester but when I go back to Peterborough I'll rip it off and put it the other way round.
that's what I told him to do. :) also suggest breaking out the greenstuff and some plastic rod bitz. I always liked that Sketch, I'm excited to see it "come to like". Hopefully He'll do the "chaplain" as well. :)
"chaplain" Chell
http://img.photobucket.com/albums/v650/Cpt_Tiberius/Chell2_hi-WORK-LOREZ.jpg
-T.
Ah the old Relictor Chaplain whose B/W image doubles as a Castigator Veteran heh. :)
involving a Word Bearers warband...
What is it with you and Word Bearers all the time! :P
Here is my converted AoBR Captain... just as an inspiration ;)
front:
http://666kb.com/i/b35u7nlfxedo40jos.jpg
http://666kb.com/i/b35u7yic32z53jelo.jpg
back:
http://666kb.com/i/b35u8mcoqyxsa6qwc.jpg
the banner broke off... i have to repair it some day.
That's actually the axe bit I am planning on using, though the Thane conversion's taken a back seat whilst I've had the chance to paint.
Here's a starting point, though Midian's since furnished me with a very good tutorial on painting grey so these might end up being re-worked:
http://i189.photobucket.com/albums/z121/mnesimache/BlackCompany/Relictors-0006.jpg
http://i189.photobucket.com/albums/z121/mnesimache/BlackCompany/Relictors-0007.jpg
http://i189.photobucket.com/albums/z121/mnesimache/BlackCompany/Relictors-0008.jpg
  • 1 month later...
A further update on Thane:
http://i189.photobucket.com/albums/z121/mnesimache/BlackCompany/Jeriko-0002.jpg
http://i189.photobucket.com/albums/z121/mnesimache/BlackCompany/Jeriko-0003.jpg
http://i189.photobucket.com/albums/z121/mnesimache/BlackCompany/Jeriko-0004.jpg
This picture includes a Catachan arm simply to showcase the pose I envisage. In actuality I'd probably use a banner arm from the Command Squad.
I really like that purity seal wrap on the left arm - very evocative of the Black Templar approach to attaching weapons to the arms, except Thane can drop the Daemon Weapon if it gets a little too hungry.
As for the legs not being 'epic' enough, I think when you get some more equipment and assorted bling on there it should be fine.
My one concern is your planned pose for the arm. Any other time and it would work a treat, but if your going by the art and giving him a bolt pistol then it's going to look seriously under balanced with the axe in the pose it's in.
Hrm... I was going to give him a bolt pistol, actually. I'm not sure about the balance; I could just go closer to the art and have his pistol raised in the air...?
As for the wrap (which Tiberius refers to sardonically as "the purity bandage") my idea was that it meant the corruption of the axe couldn't travel up his arm to his hearts.
