JEFF4i Posted December 4, 2008 Share Posted December 4, 2008 When I do my drop pod force, which is my force of choice, I don't normally take True Grit. How many of you do? I can see the potential in using it, since most of your combat is going to be close anyway. Your thoughts? Link to comment https://bolterandchainsword.com/topic/153999-true-grit-drop-pod/ Share on other sites More sharing options...
saphius Posted December 4, 2008 Share Posted December 4, 2008 Take True Grit? It's a special rule that we get and don't buy?.. If by take True Grit you mean give you Grey Hunters bolters... in a DP list that's what you should be doing. I usually do 5 with bolters, one spec wep, 2 PP, and a PW or two. I would think most Wolves players would be inclined to take even more bolters though. Link to comment https://bolterandchainsword.com/topic/153999-true-grit-drop-pod/#findComment-1795400 Share on other sites More sharing options...
Bran Scalphunter Posted December 4, 2008 Share Posted December 4, 2008 True-Grit is always there- its a built in rule. As for DP squad I'd go: 10 Hunters Plasma/Flamer Power fist, bolter Power weapon, bolt pistol plasma pistol, ccw x2 bolter, ccw x5 frags No Codex at hand so I can't tell ya if it's worth the points, but I like this set up the most. Allows plenty of dakka on landfall, and once they try to swarm you you can krump them with power fist and power weapon attacks. Link to comment https://bolterandchainsword.com/topic/153999-true-grit-drop-pod/#findComment-1795423 Share on other sites More sharing options...
JEFF4i Posted December 4, 2008 Author Share Posted December 4, 2008 Yeah, I'm a tard, hehehe. Misread the rule, was thrown, bought into it, and then realized my folly, all in about...16 hours. Link to comment https://bolterandchainsword.com/topic/153999-true-grit-drop-pod/#findComment-1795428 Share on other sites More sharing options...
williamdelgray Posted December 4, 2008 Share Posted December 4, 2008 When I read the title, I read it as actually using the drop pod with True Grit. I lol'd a little. Link to comment https://bolterandchainsword.com/topic/153999-true-grit-drop-pod/#findComment-1795447 Share on other sites More sharing options...
Blade_of_Russ Posted December 4, 2008 Share Posted December 4, 2008 I always make use of True Grit. a Grey Hunter using True Grit will always have 2 attacks in H2H (he gets the 2 weapon bonus, but never gets the charging bonus). It does mean they can't shoot before charging, but as there's no benefit to charging (no additional attack) you might as well do the shooting (which, assuming the unit has no special melee weapons, has a slightly better chance of causing a wound) and let the other side charge at you. If you really want to focus on H2H when exiting the drop pods, just go with BCs, who get more attacks anyway. Link to comment https://bolterandchainsword.com/topic/153999-true-grit-drop-pod/#findComment-1796120 Share on other sites More sharing options...
The_Betrayed_Spacewolf Posted December 4, 2008 Share Posted December 4, 2008 im using pods more and more these days. since i have only one i usually put a good bit on it to make sure that whatever it drops behind dies. load out drop pod deathwind launcher or whatever it is rune priest frost and plasma pistol 10 grey hunters 2 plasma pistols, plasma gun, power fist and weapon, bolters 1 wolf guard pack leader plasma pistol and thunder hammer 6 plasma shots generally ensure something dies kills so far in 4 games 1 vindicator and dread templars defiler and chaos marine squad chaos marines whirlwind and dread along with another squad of marines against dark angel a necron squad well technically after a mishap roll i landed behind a necron army in a carnage 3rd edition mission. lit up one squad most got up (lord was near by with the orb) he turned everything on them and killed all but the rune priest who charged a squad killed 3 and had them running and caught them Link to comment https://bolterandchainsword.com/topic/153999-true-grit-drop-pod/#findComment-1796298 Share on other sites More sharing options...
