Pants Posted December 4, 2008 Share Posted December 4, 2008 Well, I've taken to building my Sternguard Vets between painting and building the regular marines, as something nice to break up the monotany. What I've done for some of them was use the assault squad legs to make them look more dynamic, like they are running. Then I've used regular shoulderpads and just added purity seals and oath papers/tabards to them. For the backpacks I am going to try and find the dragon heads from the chaos vehicle sprue and make those the exhaust vents on them. I just need to know what to use for the firedrake hides. I was thinking the new dark elf plastic corsairs, but I hear that they're cloaks are attatched to their backs, so that won't work. The next idea would be lizardmen sheilds, but those might be hard to find. What I'm saying is that I really don't want to convert 20 firedrake hides. (10 for my vets, 10 for my termies) I will try to get some pictures of the two I have been working on posted later, but I still need to know what to do with the hides. Link to comment https://bolterandchainsword.com/topic/154052-salamanders-sternguard-vets/ Share on other sites More sharing options...
Castlerook Posted December 4, 2008 Share Posted December 4, 2008 I'm pretty sure the Corsair cloaks are seperate from the bodies. Even if the aren't a little green stuff can cover any damage. (If you don't like using GS, trim the cloaks to below the backpack and work around it). Link to comment https://bolterandchainsword.com/topic/154052-salamanders-sternguard-vets/#findComment-1796098 Share on other sites More sharing options...
Ein Posted December 4, 2008 Share Posted December 4, 2008 Corsairs do have part of their torsos cast into their cloaks, but it's pretty trivial to carve that stuff away with a sharp knife and some patience. http://www.fusedcreations.com/adam/salsgt1.jpg http://www.fusedcreations.com/adam/salsgt2.jpg The hardest part is getting it to sit close enough to the torso that you can comfortably fit the backpack overtop. I actually filed the cloak under the backpack down a bit so it'd sit flat. Link to comment https://bolterandchainsword.com/topic/154052-salamanders-sternguard-vets/#findComment-1796203 Share on other sites More sharing options...
Pants Posted December 4, 2008 Author Share Posted December 4, 2008 Okay, that looks excellent. I was planning on putting them not always on the back, but that may end up being the case with most of the vets since that's the easiest place to put them. Link to comment https://bolterandchainsword.com/topic/154052-salamanders-sternguard-vets/#findComment-1796323 Share on other sites More sharing options...
Captain Mick Posted December 4, 2008 Share Posted December 4, 2008 Looks fantastic cant wait to see it painted. ^_^ Link to comment https://bolterandchainsword.com/topic/154052-salamanders-sternguard-vets/#findComment-1796338 Share on other sites More sharing options...
