Pre-Heresy Emperor's Children tutorial
esinhorn
There are a few things from a modeling standpoint about the Emperors Children
A)They are the ONLY Legion permitted to wear the Aquilla.
(The Double-headed eagle)
If you are using the pose like I have hear where the arms cover the chest it is not as important that if you have a clear view of the chest
B)They have lots and lots of bling and were considered to go overboard with it by almost every other legion.
Now you want to put some extras on the model but don't get too crazy remember less is more
For this model I used the roman tabard and painted the bolter gold to help portray this
With this in mind we begin painting
1)I started with a white undercoat which helps get the right shade of purple later on
http://i49.photobucket.com/albums/f295/wilis516/Picture080-1.jpg
2)I basecoated the armor in Hormguant Purple,any leather Scorched Brown ,the eyes and oaths of movement(purity seals) goblin green and dheneb stone , any trim and the tips of the tabbard shining gold,and boltgun metal for any steel
Remember even coverage for the basecoat is key to a good looking model that is not blotchy,give it one more coat than you think it needs
http://i49.photobucket.com/albums/f295/wilis516/Picture081-1.jpg
3)Then use a 50/50 mix of warlock purple and liche purple and paint the armor plate
-Then use a thinned purple wash on the plate,bolter and trim,and tabbard tips
-Then use a thinned green wash to go over the oath,eyes and bolter case,and tabbard tips
-Then use a thinned black wash on the clip and barrel of the boltgun
-Then go back over the armor plate with the 50/50 mix being careful not to let it bleed into the carcks and crevaces where the wash is.
http://i49.photobucket.com/albums/f295/wilis516/Picture084-1.jpg
4)Then use warlock purple for the highlights on the armor plate and use Dark Flesh to go over the leather
-use goblin green for the hightlights on the green as the wash should of darkened it up quite a bit
-If you have'nt yet finish the oath by giving it a gryphonne sepia wash then do the script with a black and scorched brown mix.
(pure black is too harsh for purity seals IMO)
http://i49.photobucket.com/albums/f295/wilis516/Picture079-1.jpg
5)For the badge use this tutorial by Dargor (thats what I did)
http://z15.invisionfree.com/The_Great_Crus...?showtopic=1385
