LPetersson Posted December 10, 2008 Share Posted December 10, 2008 It's attacks can count as frostblade or PF attacks, but does the PF attacks strike with I1 like aPF or I5 which is Logan's initiative? I'm a bit on the fence but leaning towards I1... Any thoughts? Link to comment https://bolterandchainsword.com/topic/154527-axe-of-morkai/ Share on other sites More sharing options...
Bran Scalphunter Posted December 10, 2008 Share Posted December 10, 2008 If it can be used as a power fist, it uses the power fist's rules, so any PF attacks will strike at I1. I like splitting 2 Frost and 2 Power Fist when I use Logan on big gribblies. Link to comment https://bolterandchainsword.com/topic/154527-axe-of-morkai/#findComment-1802292 Share on other sites More sharing options...
LPetersson Posted December 10, 2008 Author Share Posted December 10, 2008 That's what I figured as well, cheers :rolleyes: Although I was hoping someone had proof otherwise, but that would just be too OP I supoose :-) Link to comment https://bolterandchainsword.com/topic/154527-axe-of-morkai/#findComment-1802294 Share on other sites More sharing options...
Wolf89 Posted December 10, 2008 Share Posted December 10, 2008 That's what I figured as well, cheers ^_^ Although I was hoping someone had proof otherwise, but that would just be too OP I supoose :-) Bran is right, as for proof, it's in the Axe's description: Logan can choose to use either as a frost blade or as a power fist. He can choose to split his attacks between the two different weapon types, for example... C:SW pg. 27 It's a weapon type, as per rules of powerfist, if chosen as that weapon type, it will strike last. ;) Link to comment https://bolterandchainsword.com/topic/154527-axe-of-morkai/#findComment-1802346 Share on other sites More sharing options...
Bran Scalphunter Posted December 10, 2008 Share Posted December 10, 2008 Bah, who needs proof when you have a shiny Signature Badge that says I'm a member of the 4 most Rules Learned members of the Fang? Don't ask for proof of me actually being well versed in the Rules ^_^ Link to comment https://bolterandchainsword.com/topic/154527-axe-of-morkai/#findComment-1802360 Share on other sites More sharing options...
The_Betrayed_Spacewolf Posted December 10, 2008 Share Posted December 10, 2008 too bad most of them are getting long in the fang and may need to go on longer and more frequent walks these days Link to comment https://bolterandchainsword.com/topic/154527-axe-of-morkai/#findComment-1802401 Share on other sites More sharing options...
