Bradskey Posted December 10, 2008 Share Posted December 10, 2008 Example: In the shooting phase, a pack of grey hunters rapid fire into a pack of ork boys that are 6" away. Then the orks charge the grey hunters. The grey hunters countercharge (after taking a leadership test) with two attacks each. Is this statement correct? Thanks in advance ^_^ Link to comment https://bolterandchainsword.com/topic/154536-is-this-statement-correct/ Share on other sites More sharing options...
saphius Posted December 10, 2008 Share Posted December 10, 2008 Assuming they all have bolters and CCWs/PWs - Yes. If they have a Bolter and a PF - Not unless they pass the LD check. Link to comment https://bolterandchainsword.com/topic/154536-is-this-statement-correct/#findComment-1802393 Share on other sites More sharing options...
Bradskey Posted December 10, 2008 Author Share Posted December 10, 2008 thanks, yea I meant that if they all had bolters and CC weapons. Link to comment https://bolterandchainsword.com/topic/154536-is-this-statement-correct/#findComment-1802405 Share on other sites More sharing options...
Wolf89 Posted December 10, 2008 Share Posted December 10, 2008 Assuming they all have bolters and CCWs/PWs - Yes. If they have a Bolter and a PF - Not unless they pass the LD check. Actually the counter is completely independent of what weaponry they have, because they just count as charging with a passed Ld test. Therefore, if it was a bp/ccw it would be 3 attacks with passed Ld test, but PF is only 2 no matter what because you don't get the bonus unless you have a 2nd power fist. Also something to note, during the consecutive rounds of combat, the bolter acts as another ccw so you get 2 attacks no matter what. Also wolf pelt will stack with these so you can have a lot of attacks on the counter. :rolleyes: Link to comment https://bolterandchainsword.com/topic/154536-is-this-statement-correct/#findComment-1802458 Share on other sites More sharing options...
WolfLordLars Posted December 10, 2008 Share Posted December 10, 2008 To add on to answers already given: This assumes 10 GH all with Bolter/CCW-PW. Here are answers: - Will they get 2 attacks in CC? (Yes, without the counter-attack, Bolter counts as CCW) - Will they get 3 attacks in CC with counter-charge? (No, bolters negate the +1 for charging) - If I had a PF, how many attacks does he get with Bolter/PF? (1, no bonus for the 2nd ccw) - How about if I counter-charge with a Bolter/PF? (2, but you have to state that your not using the bolter as a CCW, which wouldnt do him any good anyway - the additional attack is from the counter-attack) In the end, GH with bolters have no need to counter-attack, as they dont get the bonus to attack because of their bolters. The only model that would is the Power Fist. If they have Bolt Pistols, they DO need to counter-attack, as it will bring them to 3 attacks each. Link to comment https://bolterandchainsword.com/topic/154536-is-this-statement-correct/#findComment-1803066 Share on other sites More sharing options...
