El-Diablo Posted December 10, 2008 Share Posted December 10, 2008 I did this as a favour for Commissar Molotov, hopefully someone else might find it useful. Colours needed - -Chaos Black -Skull White -Adeptus Battlegrey -Codex Grey -Fortress Grey -Badab Black -Boltgun Metal -Chainmail -Mithril Silver -Scorched Brown -Dark Flesh -Dheneb Stone -Bleached Bone -Devlan Mud -Red Gore -Blood Red -Khemri Brown -Kommando Khaki Stage 1 - Basecoat the armoured areas Adeptus Battlegrey. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage1.jpg Stage 2 - Wash the whole thing with a heavy wash of Badab Black. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage2.jpg Stage 3 - Overbrush the armour with Adeptus Battlegrey. Overbrushing is essentially drybrushing, but with a wet brush. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage3.jpg Stage 4 - Quick highlights with Codex Grey - highlight everything except the darkest areas. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage4.jpg Stage 5 - Apply fine highlights to the top edges with Fortress Grey. Basically, anything at the top of the figure - top of helmet, top of shoulder pads, toes etc. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage5.jpg Stage 6 - Glaze the whole lot with Badab Black, watered down until its virtually see through. Before painting it on, gently dab the brush on a piece of tissue (use the stuff you get for the kitchen, not toilet tissue) to take out the excess water out of the brush. If it takes more than a few seconds to dry on the figure, you've got too much watered paint on the brush. Hit the tissue again and carry on. At this stage I painted everything else Chaos Black and gave the moulded tactical arrow a coat of Fortress Grey. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage6.jpg Stage 7 - The Metal I would of done this as 4 separate pictures but metal is a pain to photograph. -Basecoat Boltgun Metal. -Highlight Chainmail. -Edge highlight Mithril Silver. -Wash with Badab Black. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage7-Metal.jpg Stage 8 - Leather -Basecoat Scorched Brown. -Layer a 60/40 mix of Scorched Brown/Dark Flesh, leaving Scorched Brown in the recesses. -Edge Highlight with thinned Dark Flesh. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage8-Leather.jpg Stage 9 - Skulls & Parchment These 2 are the same except for the base colour. 1-Basecoat the skulls with Dheneb Stone and the parchment with Bleached Bone. 2-Wash with Devlan Mud. 3-Highlight the skulls with Dheneb Stone and the parchment with Bleached Bone. 4-Add Skull White to Dheneb Stone to highlight the skulls, add Skull White to Bleached Bone to highlight the parchment. 5-Using thinned down Chaos Black, paint thin lines on the parchment to represent text. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage9-SkullsParchment.jpg Stage 10 - Lenses and Wax Seals 1-Basecoat Red Gore. 2-Layer Blood Red over the top, leaving Red Gore in the recesses. On the lenses, leave some Red Gore showing at the back. 3-Add a tiny spot of Skull White at the back of each lense for reflection points. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage10-LensesandWaxSeals.jpg Stage 11 - Black -Edge highlight the black areas with a 50/50 mix of Chaos Black/Adeptus Battlegrey. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage11-Black.jpg Stage 12 - Chapter Badge 1-Paint a circle and square with thinned Fortress Grey, then fill in. 2-Go over the grey with thinned Skull White - you'll probably need 3 or 4 thin layers to get it smooth. 3-Tidy up the shape with thinned Chaos Black and add the details - eye, nose and teeth. At this point I would paint the tactical arrow - layer with a 50/50 Fortress Grey/Skull White mix, then layer with pure Skull White, sing as many thin layers as it takes to get it smooth. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage12-ChapterBadge.jpg Stage 13 - Weathering -Water down Scorched Brown (approx 10/1 water/Scorched Brown) and glaze around panel lines, joints and anywhere else dirt would collect. -Do the same with Catachan Green, then with Bestial Brown. -Overall theres around 15 layers of colour glazed on. For more info on glazing see Lunchbox's glazing article. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/Stage13-Weathering.jpg Next, base however you feel - i've washed the sand with Brown Ink then drybrushed it with Khemri Brown then Kommando Khaki. Paint the rim Scorched Brown and add static grass to taste. http://i3.photobucket.com/albums/y57/El-Diablo/Relictors/Relictors%20Tutorial/RelictorFinal.jpg Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/ Share on other sites More sharing options...
Commissar Molotov Posted December 10, 2008 Share Posted December 10, 2008 Thank you for the tutorial, Midian! It's certainly appreciated. I'm glad that you've broken it down into what seem easily achievable steps - and the Chapter badge tutorial will definitely come in handy! Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1803107 Share on other sites More sharing options...
El-Diablo Posted December 10, 2008 Author Share Posted December 10, 2008 Cheers Mol. Considering I painted most of it without a solid idea im pretty happy with it. Hey, if it gets you a painted army then i've done a good job! Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1803121 Share on other sites More sharing options...
tagsta Posted December 10, 2008 Share Posted December 10, 2008 amazing! thank you for this Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1803214 Share on other sites More sharing options...
Sigismund Himself Posted December 11, 2008 Share Posted December 11, 2008 Impressive Midias, definitely a place for this in the Librarium, if you want it up there Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1803607 Share on other sites More sharing options...
El-Diablo Posted December 11, 2008 Author Share Posted December 11, 2008 Impressive Midian, definitely a place for this in the Librarium, if you want it up there :D Fixed :o Feel free to put it in the Librarium Sigismund, be good to see some use out of it. Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1803943 Share on other sites More sharing options...
ikik Posted December 11, 2008 Share Posted December 11, 2008 great tutorial, I will definently use this for my relictor bike squad, Thanks brother ^_^ Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1804393 Share on other sites More sharing options...
Mithrilforge Posted December 14, 2008 Share Posted December 14, 2008 Excellent work there Midian :tu: x2 seeing the easy step by step tutorial makes me want to make a small relictors army... just cause i can ;) Many thanks for this!! the skull breakdown is very useful. Mithril Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1807926 Share on other sites More sharing options...
Terminatorinhell Posted December 14, 2008 Share Posted December 14, 2008 excellent work, i kinda like these relictors! Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1807929 Share on other sites More sharing options...
Tyrannicide Posted December 15, 2008 Share Posted December 15, 2008 This is awesome. I really do love your clean style of painting and you make it seem so simple in this tutorial too! :D Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1808226 Share on other sites More sharing options...
Sigismund Himself Posted December 21, 2008 Share Posted December 21, 2008 Courtesy of Ferrus Manus' hard work, the tutorial has been added to the Librarium. Linky. Link to comment https://bolterandchainsword.com/topic/154580-painting-relictors-tutorial/#findComment-1815180 Share on other sites More sharing options...
