Grand Master Raziel Secundus Posted December 26, 2008 Share Posted December 26, 2008 Hi Folks Quick question... what does everyone do with those small leftover bits of greenstuff? I always seem to end up with a small ball or so and since I live miles away from a reliable source, I hate to waste the stuff. It would make me feel better using the bits so as they would not go completely unused... so any ideas??? Cheers in advance :confused: Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/ Share on other sites More sharing options...
Dark Bjoern Posted December 26, 2008 Share Posted December 26, 2008 I made balls out of the rest in a size that i can cut out wedges for shoulder joints to repositioning arms. Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1820502 Share on other sites More sharing options...
Mal Posted December 26, 2008 Share Posted December 26, 2008 I make small balls out of it, and when doing a larger project using other modelling clay as a base form, i'll add the GS balls in the mass to reduce loss of clay. Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1820520 Share on other sites More sharing options...
Daeothar Posted December 26, 2008 Share Posted December 26, 2008 I've been using leftovers to sculpt mushrooms to go on bases. Just make a tiny ball and press a rod into one side, then open up the cupshape you've created. Make another, slightly smaller ball (elongated shape if desired) and push it into the hole and presto; mushroom! Needless to say I've got tons of mushrooms in my bitz box, especially since I don't actually play Orks in any system... :( Other than that, I've made ready to go bitz with them; floor panels, by making flat sheets and pressing in detailed stuff (like teardrop plating), or making handles/grips by rolling Greenstuff / ProCreate around a bit of wire (usually straighened paperclip) and rolling it over a mould I made, also from GS, by rolling the grip portion of an exacto knifehandle over it. By rolling the wire with putty over the hardened mould, I get myself great looking rods with a moulded pattern in it. This can be used for canes, staffs, sword handles etc etc. (I've only used this for Warmachine stuff so far, but it lends itself well for 40K too of course). Just make a habit of doing that little bit of extra (but not hard) work when you're done sculpting, and soon, you'll have a heatlhy amount of extra bits in your bitsbox to use or trade... :confused: Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1820523 Share on other sites More sharing options...
Serraphim Posted December 26, 2008 Share Posted December 26, 2008 I try and roll mine out into long sausages, which in a pinch make really good rods or rivets. Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1820574 Share on other sites More sharing options...
Noserenda Posted December 26, 2008 Share Posted December 26, 2008 I just tend to lump it on to bases to break up the flatness a bit pre sand and gubbins. Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1820625 Share on other sites More sharing options...
Metal Fingered Villain Posted December 26, 2008 Share Posted December 26, 2008 I am a fan of having one or two sculpts that are still in the bulking stages and just stick the excess gs that I'm not using onto them. Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1820718 Share on other sites More sharing options...
IamJacksUserName Posted December 26, 2008 Share Posted December 26, 2008 I roll it out into thin long lines, and later use it for tubes and wiring on other models. Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1820806 Share on other sites More sharing options...
ShinyRhino Posted December 29, 2008 Share Posted December 29, 2008 I use mine to plug the holes in all the slotta bases I have, so I can pin non-slotta Marines to them later. Or, I roll the extra into a ball, then chop it up later on with a hobby knife to make flagstones, or chunks of rock. Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1822669 Share on other sites More sharing options...
Grand Master Raziel Secundus Posted December 29, 2008 Author Share Posted December 29, 2008 Wow, these are all excellent ideas.... Hopefully now I won't feel so wasteful now ;) Thanks!!! Cheers Link to comment https://bolterandchainsword.com/topic/155822-what-to-do-with-gs/#findComment-1822702 Share on other sites More sharing options...
