T14 Posted January 7, 2009 Share Posted January 7, 2009 Greetings. This is my rough step-by-step picture guide to adding select BT bits to AOBR terminators. All pics contain an unmodified bit (the leftmost one) and a modified bit (the rightmost one). I think the pics are pretty self-explanatory, but give us a shout if you feel any clarifications are needed, and I\'ll happily try to elaborate. My goal here was to reach a dry-fit stage, where you can either just glue it together as-is, or neaten joins etc up abit with GreenStuff. What you need: - AOBR terminator with bolter and powerfist - BT tabard bit - BT termie shoulder pad - BT power fist - a craft/hobby/X-acto knife - a wee bit o' patience ;) STEP 1: Modifying the body. Here you just need to shave down the abdomen and groin area, as shown. I think I overdid it abit, but the idea is to shave things down flat so the tabard will fit. i also took a sliver off the leg that didnt strictly need to go. Live and learn :angry: [/clearfloat] STEP 2: Modifying the AOBR chest/head bit. Here you want to remove just enough of the chest plate to accomodate a shaved-down tabard bit. I did this by gently shaving off thin flakes with a scalpel until it got to where I needed it to be. STEP 3: Modifying the BT Tabard bit. This part is a wee bit tricky as you might need to shave bits off in many places to make it fit snug. Modify the back, collar, belt and inside a little bit at a time until it fits with your AOBR chest/head bit. You should be able to spot all the places where I did a little trimming if you look closely :D STEP 4: Modifying the Bolter arm. Here we want to whittle away the AOBR pauldron layer until the shoulder becomes slender enough to accept the BT termie shoulder pad. Patience and lots of dry-fitting helps here. Step 5: Modifying the powerfist arm. It is just a simple weapon swap really. I still need to replace the power cable, but as the cable types are different between the AOBR and BT kits, I have decided to find me some guitar string wire to add in place of the AOBR cable. I havent been to the shops yet, sorry. Finished Product The results are below. Enjoy and thanks for reading - T14 [clearfloat] Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/ Share on other sites More sharing options...
Sigismund Himself Posted January 7, 2009 Share Posted January 7, 2009 Definitely something I would love to see in the Librarium, T14 :rolleyes: Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1833873 Share on other sites More sharing options...
Terminatorinhell Posted January 7, 2009 Share Posted January 7, 2009 yes it belongs in the librarium, very useful! Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1833886 Share on other sites More sharing options...
flintlocklaser Posted January 7, 2009 Share Posted January 7, 2009 Agreed, it's a great conversion, and it's a good match for the BT Termie technique from the French GW site. Another vote for Librariumification! (if that's even a word...) Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1833934 Share on other sites More sharing options...
Starbuck_ Posted January 7, 2009 Share Posted January 7, 2009 Superb tut. One of the things I don't like about aobr is the lack of individuality to the models, definatly a great way to do it. Â I think this better done than the one by GW. Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1833950 Share on other sites More sharing options...
Shortsonfire79 Posted January 8, 2009 Share Posted January 8, 2009 Noice! I love it! Great, thanks. VERRYY helpfull..now..to get some more BT pieces...and to get an AoBR.. Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1834232 Share on other sites More sharing options...
T14 Posted January 8, 2009 Author Share Posted January 8, 2009 Definitely something I would love to see in the Librarium, T14 :) Â I'd be Honored Brother, but would need guidance as to how :P Â Cheers guys - T14 Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1834251 Share on other sites More sharing options...
Sigismund Himself Posted January 11, 2009 Share Posted January 11, 2009 There's now this article to help you you out, T14 :teehee: Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1838328 Share on other sites More sharing options...
T14 Posted January 12, 2009 Author Share Posted January 12, 2009 you sir, are a star ;)  I'll get on it today... and am working on the next installment in the series ;)  EDIT: Submitted. I think I left the formatting abit wonky tho :rolleyes: But I've corrected the last details and edited my first post here with the final formatting adjustments if ya wanna cope paste from that Sig  Bambi has nuffin' on me ;) - T14 Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1839537 Share on other sites More sharing options...
Sigismund Himself Posted January 12, 2009 Share Posted January 12, 2009 Thanks for submitting it Thomas, it was simple to put in :D Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1839726 Share on other sites More sharing options...
paulson games Posted January 19, 2009 Share Posted January 19, 2009 Great conversion, I've been converting regular terminators to BT ones and didn't think about trying it on the black reach termies. Now I have a good source to save me time figuring it out. Thanks Link to comment https://bolterandchainsword.com/topic/156835-modelling-templarrific-aobr-termies-howto/#findComment-1849020 Share on other sites More sharing options...
