Deep Striking a Rhino with GoI
DevilUknow
I couldn't find anything searching, but sorry if this is a repeat question.
my CRAZY friend proposes that he can put a libby in a Rhino full of marines (will, 9 marines) and use Gate of Infinity to deep strike the tank within 24" based on the fact that
a. it moves the libby and the squad he's attached to
c. since the rhino is a dedicated transport, it is part of the squad <-- I'm almost totally sure this is wrong
b. psychic powers can be used in transports
is he CRAZY?
https://bolterandchainsword.com/topic/157226-deep-striking-a-rhino-with-goi/
Not as much as it would seem. The GoI power states that the Librarian can take members of his unit with him. The transport is not part of the unit, so does not get transported, and with 5th edition the Librarian is no longer considered off the table when in a transport so can use his powers while in one. Therefore, you can pull a squad out of its transport.
so its my understanding that i could
1. move the rhino w/ libby and 9 marines
2. cast GoI and deep strike within 24" of their current location
3. run
optional
4. cast The Quickening and assault with the libby if he's an epistolary never mind...
No, the libby doesn't transport the tank.
He can deepstrike himself and his squad from inside the tank. The measurement is taken from the hull of the vehicle.
This is done at the beginning of the movement phase, so there can be no moves of any sort before this happens.
You cannot move in the movement phase after gating, because it uses the rules for deep striking, which say you can't.
You can run or shoot after gating.
You cannot assault after gating.
