Single Grinders not useful?
Well I usually run two, especially in bigger games. I have however had success with one. I just make mine as flexible as possible to achieve the maximum kills.
Although again armies geared for anti-tank, they may have a harder time than a Daemon Prince or more troops.
Being the only vehicle, Soul Grinders will attract lots of anti-tank fire, so it's usually best to have a couple or a trio so you'll still have some functional after the enemy does their shooting.
Well in truth, alot of the same weapons that will be directed at a Soul Grinder are also going to be used to take out Daemon Princes or any kind of Greater Daemon.
I think the most direct threat to the Soul Grinder, like all vehicles, is Melta weapons. The advantage that Daemons have is that few armies want to get into close range with any kind of Daemon and Melta really requires that.
Running a squad of Bloodletters or Daemonettes next to your Soul Grinder would protect it from most fast moving Melta squads (think SM Attack Bikes) or atleast be able to bring vengence down upon the enemy squad if they're able to kill your Grinder.
The reason is simple. Whereas one lascannon is barely going to tickle a DP/GD, it could kill a Grinder. Chances are low, but most opponents with a few AT guns in Troops choices (Tactical Squads) will take a few potshots at the Grinder, thus limiting it's effectiveness.
Personal opinion but I'd be happy with that. If an entire Tac squad or two is wasting their fire on a Soul Grinder who is very likely to just shrug off the anti-tank shot instead of concentrating on the DP where their Bolters would not be wasted, then I say good. :(
having three soul grinders on the table can put down punishing firepower and close combat prowess
it is okay to field one because you it has back 11 and front and sides 13 which is proof of most close combat and heavy weapon attacks
also who wouldnt want to field three!!
Personal opinion but I'd be happy with that. If an entire Tac squad or two is wasting their fire on a Soul Grinder who is very likely to just shrug off the anti-tank shot instead of concentrating on the DP where their Bolters would not be wasted, then I say good. :Elite:
Heck yeah! Especially if you are running a DP of Nurgle w/ iron hide so the bolter fire just bounces off of you...(Tough 6 vs str 4 = 6 to wound, with anything getting throuh subject to a 3+ arm save!)
