Einholt Posted January 13, 2009 Share Posted January 13, 2009 Started on these last night, marine on the left is there for scale comparison, they will all be greenstuffed like the one that already is, what do you guys think of the scale / poses, look natural to you? http://i38.photobucket.com/albums/e109/Einholt/PICT1110.jpg Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/ Share on other sites More sharing options...
son of nocturne Posted January 13, 2009 Share Posted January 13, 2009 Alrite bud, your fists look good but they are a litle bit lanky, the poses are absolutley fine. If you just put a GS or Plasticard ring round the waist band they would look good then! S.O.N. Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1841424 Share on other sites More sharing options...
Einholt Posted January 13, 2009 Author Share Posted January 13, 2009 Whats the best way to make a plasticard ring for the belt extension, just cant seen to think how I can do it, will the plasticard bend and hold with superglue if I use a thin strip? Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1841439 Share on other sites More sharing options...
son of nocturne Posted January 13, 2009 Share Posted January 13, 2009 Id say cut a bit of plasticard that is a bit thicker than the belt, tack it on one end with super glue, wait for the glue to fully set, then you should be able to ply the rest of the card round with ease but stick with super glue as it dries fast enough to hold it down. once thats done you can trim the belt down to the correct thinness and it should look fine! S.O.N. Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1841521 Share on other sites More sharing options...
emperor's hand Posted January 13, 2009 Share Posted January 13, 2009 ey like them i only think they are still a bit to small but that's just my opinion. i like to see more of them later on. true scale tech marine Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1841671 Share on other sites More sharing options...
Seres Blackthorn Posted January 13, 2009 Share Posted January 13, 2009 Well if your a person to like Actual Scale Marines then go to Emperor's hand's page but this is true scale. Nice thread jacking Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1841946 Share on other sites More sharing options...
Lestat Posted January 13, 2009 Share Posted January 13, 2009 Started on these last night, marine on the left is there for scale comparison, they will all be greenstuffed like the one that already is, what do you guys think of the scale / poses, look natural to you? http://i38.photobucket.com/albums/e109/Einholt/PICT1110.jpg Try bulking out the thighs - they look a little too thin. I had the same problem when I was building a couple of truescale marines. I used a couple of the Terminator groin guards to act as armour for the thigh. Just trim the piece on the back of the guard and glue in place. Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1842008 Share on other sites More sharing options...
Sons of Horus Posted January 14, 2009 Share Posted January 14, 2009 i can tell they're bigger but you should post a pic of them beside a normal marine. Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1842567 Share on other sites More sharing options...
Einholt Posted January 14, 2009 Author Share Posted January 14, 2009 Ther marine on the far left is a normally scaled one :( Link to comment https://bolterandchainsword.com/topic/157426-wip-truescale-imperial-fists/#findComment-1842963 Share on other sites More sharing options...
