Tratos The torn Posted January 15, 2009 Share Posted January 15, 2009 does anyone have a good tut for painting blood? (links are fine too) :) Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/ Share on other sites More sharing options...
NemFX Posted January 15, 2009 Share Posted January 15, 2009 Dark red paint, put it on a bristle brush, then flick your finger over the top of it to make it do the little bloodsplatter effect. The brush shouldn't come in contact with the model. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1845004 Share on other sites More sharing options...
Sigismund Himself Posted January 15, 2009 Share Posted January 15, 2009 Searchy and the Librarium are your friends for finding tutorials. For example, this one may be of help to you. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1845155 Share on other sites More sharing options...
Master Kashnizel Posted January 16, 2009 Share Posted January 16, 2009 I use a fine detail brush to do straight lines up a sword and the apply red ink+chestnut ink to those areas. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1845719 Share on other sites More sharing options...
Stefoserpent Posted January 16, 2009 Share Posted January 16, 2009 Once I saw a tutorial on gamesworkshop site that used red gore , PVA glue and some modeling sand to create a blood and gore effect. ^_^ Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1845905 Share on other sites More sharing options...
Ganuus Posted January 17, 2009 Share Posted January 17, 2009 Tamiya Clear Red. Apply, mix a tiny bit of black on the pallet, then apply when it's slightly dried. Brings a good gore effect. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1846589 Share on other sites More sharing options...
Levett Posted January 17, 2009 Share Posted January 17, 2009 Try dark flesh, then 50/50 Carmine Red (Vallejo) + Dark Flesh over the same areas, leaving a little of the first layer , then paint over with Tamiya Clear Red. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1846861 Share on other sites More sharing options...
Brother Captain Andrecus Posted January 27, 2009 Share Posted January 27, 2009 Another good method is to make a splotchy shape using Gore Red, then highlight that with Blood Red, and then when it dries, go over it with a coat of Vallejo Clear Gloss. That'll make a wet-looking blood splotch, impressive, and easier than some other methods. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1860352 Share on other sites More sharing options...
eyescrossed Posted January 28, 2009 Share Posted January 28, 2009 The one Sigismund Himself posted is AWESOME! I've used it 2-3 times, and I can say that it looks awesome. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1861154 Share on other sites More sharing options...
Darth Bob Posted January 30, 2009 Share Posted January 30, 2009 Tamiya Clear Red. Apply, mix a tiny bit of black on the pallet, then apply when it's slightly dried. Brings a good gore effect. Bingo! This guy has the idea. Tamiya Clear Red, at least in my opinion, is the best way to do blood and gore bar none. Here's a tutorial from Lonewolf over at Throne of Skulls. Truly beautiful gore work. http://www.cheddarmongers.org/prod/gallery2/d/9542-2/deathwalker.jpg (DREAD DONE BY LONEWOLF) Look at the claws on that dread and tell me the blood doesn't look amazing. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1863644 Share on other sites More sharing options...
azrael240 Posted January 30, 2009 Share Posted January 30, 2009 one i used for my orks sand,pva glue, red gore. mix above materials into one with a od brush, paint it onto said gore area. them higlight with blood red Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1864501 Share on other sites More sharing options...
L0NEW0LF Posted January 30, 2009 Share Posted January 30, 2009 Cheers Darth Bob saved me the effort of linking it myself, glad you liked it. Definitely TCR for the win! Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1864569 Share on other sites More sharing options...
eyescrossed Posted February 1, 2009 Share Posted February 1, 2009 Oh yeah, LONEWOLF, thanks for that tutorial - it's awesome! But I find that nothing GW makes is good for blood effects. Tamiya is awesome... Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1865971 Share on other sites More sharing options...
XI Legion Posted February 5, 2009 Share Posted February 5, 2009 you can do blood effects in similar fashion using water effects (maybe it is wet effects, cant remember), PVA will work, but thickens everything up a bit, so you can either mix water effects into paint or simply apply in thin layers over desired paint for wet look. Also using snow can work nicely for adding gore, but then you will need PVA to help bind everything together, make sure to add a bit of water too otherwise it will get too thick! Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-1871740 Share on other sites More sharing options...
Replica Posted September 29, 2009 Share Posted September 29, 2009 I just make a dark red using blood red and black, then mix in a fiar bit of 'ardcoat and sponge it on with a small square of the blister pack foam insert, takes 2min. Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-2129278 Share on other sites More sharing options...
Gore Fang Posted October 6, 2009 Share Posted October 6, 2009 I use the blow technique. As terrible as that sounds :lol: It works very well. Just mix Baal Red wash and any variety of reds, add a little water, not to much, angle the model and blow. You'll quickly find your model to be soaked in realistic looking blood spatter. Change the reds up and you'll have blood spatter that looks both, stale, and fresh. Enjoy! Link to comment https://bolterandchainsword.com/topic/157679-faq-painting-blood/#findComment-2139854 Share on other sites More sharing options...
