Orby B
As cedric says, there is a difference.
Barrage weapons roll an extra D6 for scatter when targeting a model equipped with a stealth field generator.
Orbital Bombardment is a barrage weapon, so it rolls 3D6 for scatter, and can not have that modified by the BS pf the model using it.
That covers the case for Tau Stealthsuits and Sniper Drones. If you want to know how the GK Shrouding or the Vindicare's stealth suit work, I don't know.
Hope that helps!
https://bolterandchainsword.com/topic/158127-orby-b/#findComment-1853579
I haven't got my Daemonhunters book with me, but I think the Aegis rules says that Grey Knights who are out of the dice range can't be shot at.
As far as firing it at Eldar Harlequins with a Shadowseer, they have their rule clarified in their FAQ - if a barrage weapon can't make the roll to see them, they can't be shot at.
It really seems to depend on what you're shooting, as each of the stealthy units has different rules or wording.
https://bolterandchainsword.com/topic/158127-orby-b/#findComment-1855181
Shrouding can be nasty with one shot weapons.... Simply because you cannot pick another target to fire at once you've tested to see if you can see them..... now this bit is debateable.... does this 'wasted shot' count as you having fired the weapon but been unable to hit them, or you just couldn't get a goot sight so didn't fire.... the rules do not say either way IIRC.
https://bolterandchainsword.com/topic/158127-orby-b/#findComment-1855366
