When to use Aspiring Champions
As some of you know, I'm a big fan of infantry heavy armies. I normally run with 10 more CSMs than what is considered "normal" for any given army size and I trust my rank and file to do the lion's share of the work. Because of that, I give almost every squad an Aspiring Champion of some sort with the possible exception of my twin Plasmagun squads.
However more and more I'm looking at the points I spend and thinking they could be better used elsewhere, specifically with Terminators.
Figure a normal Power Weapon Champion costs 50% more than a Power Weapon Terminators and a Power Fist Champion costs more than a third more.
Of course you run into the whole issue of getting them into combat but point for point, its cheaper to go with Terminators. But does focusing all your Power Weapons/Fist in 1/2 squads end up costing you too much by weakening everything else?
All this being said, I doubt I'd leave home without my Champions.
https://bolterandchainsword.com/topic/158467-when-to-use-aspiring-champions/
I've been playtesting with and without. I think I may actually paint a few that have those cool options like twin-linked bolters, combi-weapons and such. During a game, though, it makes me a lot more confident to charge in with a fist and meltabombs.
- Blackbone
plasma gun squads in some pm builds like LR rush where 2 squads are ment for hth and two for double taping ,those rhino plasma squads can do without champions . terminators always without champions . 5 man raptor squads ment for anti tank and anti horde with 2 specials always without champions .
Specifically I was thinking about my 10 man CSMs squad with dual Flamers. They're geared for clearing out hordies or cover-huggers and in both cases a Power Weapon/Fist Champion is normally overkill due to the lowish T value or poor armor save.
Plus using Icon of Chaos Glory spoils me for LD tests.
hmmm i would 5 man raptors for anti horde , as much as troops are needed in the 5th , csm are a bit too slow to counter more then one unit per game [double that if the rhino gets stoped ] . this kind of a means you have to runs 2flamer/2melta squads and thats best used in a LR rush build , so in the end after testing one comes to the conclusion that its better to replace the csm squads with zerkers for faster unit breaking [DP charge +zerkers is enough for most normal squads] .
but that was a bit offtopic . If I had to play flamer csm I would take asp champions , the range is really short and they will end up in hth and this means counter units and then its better to do as much damge against those as possible .
Well, having the Champions also prduces another good result. Raising the LD for all is good, but carrying the icons to summon in the lesser demons to help contest or jump in and give that extra push against a troublsesome squad your locked in CC with, or to help clear an objective; Or even to use to summon i na greater demon, with more options and locations, since there is more of them all over the field. Plus, having a PF in each squad greatly increases your mobility and options for what squads can go where, and doesnt get you stuck in HTH with an opposing Defiler, or a Dreadnaught or the like.
I think its easier for squad using Icon of Chaos Glory to get away without using a Champion because you're still testing on a very good Leadership. I ran the numbers before and LD9 reroll = LD11 and LD8 reroll = LD10 so it does help to compensate for no Champion
