Scout Bikes
newach
Im not sure what bases they come with as i tend not to buy 'new' models..however i use standard cavalry bases on all my bikes.
secondly in a unit of 5 or more take 3 (max out), these are great weapons to have, also its always worth taking the cluster mines...
GC08
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856141
No, it may not be bigger. Model must be mounted on the bases they come with. Any change requires opponents consent.
Those are the rules. Having said that, most people aren't too strict about it in my experience.
you are wrong, they must be at least the size, can be bigger without any consent.
edit: cut the flaming
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856260
1. I do. Those are the rules.
2. I agree. use 3 or none.
What do you mean it is the rules
What he means is that rulewise if a model comes with a base it must be mounted on a base of at least that size(it may be bigger).
P.3 BBB states that models should be mounted on the bases they come with, any other bases you will need youyr opponents permission to use (even larger ones, sorry it was 4th ed when you didn't need to ask for that).
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856264
Airbender
Rulebook, page 3, Bases
Citadel miniatures are normally supplied with a plastic base. If so, they must be glued onto their base before they can be used in the game.
Some player like to mount their models on impressive scenic bases. As mounting your models on different-sized might affect the way they interact with the rules, make sure before the game that your opponent does not mind this.
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856268
not true, what you got there isnt RAW nor RAI.
http://i247.photobucket.com/albums/gg125/airbenderxiao/eefe5114.jpg
RAW:it says it must have a base, regardless whether the base it come with, and "impressive scenic bases" needs oks.
RAI: smaller base not okay because of reachings, high bases are vauge because of true line of sight.
and?
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856274
trying to be RAW on this point would really lead to silly points such as why multiple "Citadel miniatures" has to go on "a plastic base"
also the problem with older termie and many other model.
let us just face it, the point of this rule is that some one wouldnot have snipers on towers and co.; not bigger bases.
edit: misspelling
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856278
also with older termie and many other model.
That would be a valid point if the text said; "Citadel miniatures has to go on a single plastic base." But it doesn't. You are really reaching here.
Also your old metal Terminators was supplied with a plastic base. This is the base you should use. No problems there.
The rules are perfectly clear.
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856288
I apologize for the flaming.
so this means all of us have to unbase the double based charcaters, also old termies on the new bases......this seriously sucks.
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856294
Yes, characters can be a problem.
No, old terminators are not a problem. As long as they are mounted on the bases their came with. My 40+ metal Deathwing Terminators came with 25mm bases and they are mounted on those. Do I have to change all their bases to 40mm? No, because they are mounted on the bases they came with.
Having said that, most people don't make too much of a problem out of it in my experience.
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856302
Unfortunately so... thats one of the reasons why I stopped playing Death Wing in 5th edition.
https://bolterandchainsword.com/topic/158505-scout-bikes/#findComment-1856303
