Immolate boxed set contents?
Solax
If you buy this box can you just make a rhino out of it and not glue the top to go from rhino to immolator?
yep! You will just use the normal/stock Rhino parts.
Does it really come with all the awesome iconography that it shows?
Yep, it's honestly too much iconography for a single tank imo. I actualy had more than enough spare parts to build the immolator and give a 2nd Rhino a "Sisters' look" by using the left overs!
Is exorcist the same way?
That I don't know of for sure.... I thought the regular Exorcist was fugly so I went the SM Whirlwind route. I'd assume it would atleast have a "Sisters Bits" sprue like the immolator.
Rhino sprues + extra stuff?
That pretty much sums it up! ;)
=Empty Bolter Clip=
=Empty Bolter Clip=
ye man, i swear u get even more with the exorcist then u do the immolator
