Anders4189 Posted February 5, 2009 Share Posted February 5, 2009 Now the rule book says that the model suffers a wound with normal saves allowed, but is it a wound from the gun with its str. and AP values, and, if he survives, can he continue to use the weapon? Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/ Share on other sites More sharing options...
JamesI Posted February 5, 2009 Share Posted February 5, 2009 He suffers a wound. There is no strength or AP to the wound. Just jump right to your save. And the weapon is still operational assuming the user survives. Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/#findComment-1871160 Share on other sites More sharing options...
Chaplian Silkor Posted February 5, 2009 Share Posted February 5, 2009 If you're talking about Plasma pistols and Plasma guns, then the user can still use his weapon that turn, but if it is a Plasma Cannon, you won't be able to fire with it... Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/#findComment-1871194 Share on other sites More sharing options...
JamesI Posted February 5, 2009 Share Posted February 5, 2009 If you're talking about Plasma pistols and Plasma guns, then the user can still use his weapon that turn, but if it is a Plasma Cannon, you won't be able to fire with it... If a plasmagun was rapid firing, you'd still get the other shot, but a plasma pistol is done for that turn if it gets hot. Next turn any plasma weapon is fine though. Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/#findComment-1871202 Share on other sites More sharing options...
Chaplian Silkor Posted February 5, 2009 Share Posted February 5, 2009 If you're talking about Plasma pistols and Plasma guns, then the user can still use his weapon that turn, but if it is a Plasma Cannon, you won't be able to fire with it... If a plasmagun was rapid firing, you'd still get the other shot, but a plasma pistol is done for that turn if it gets hot. Next turn any plasma weapon is fine though. Correct, I was merely pointing out that you cannot fire the Plasma Cannon if it got hot... Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/#findComment-1871411 Share on other sites More sharing options...
Anders4189 Posted February 5, 2009 Author Share Posted February 5, 2009 Okay, thanks guys that really cleared it up for me. Mods can delete this now =) Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/#findComment-1871477 Share on other sites More sharing options...
nighthawks Posted February 5, 2009 Share Posted February 5, 2009 generally, we don't delete new threads. if it is answered, it will remain in case someone comes along searching for this same question. Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/#findComment-1871626 Share on other sites More sharing options...
Anders4189 Posted February 5, 2009 Author Share Posted February 5, 2009 Yeah that makes sense, my bad Link to comment https://bolterandchainsword.com/topic/159597-gets-hot-question/#findComment-1871695 Share on other sites More sharing options...
