750 well rounded army
750 Pts - Chaos Marines Roster
HQ: Daemon Prince (1#, 120 Pts)
1 Daemon Prince @ 120 Pts
Close Combat Weapon; Fearless; Mark of Khorne
Troops: Chaos Space Marines (11#, 245 Pts)
9 Chaos Space Marines @ 245 Pts
Bolt Pistol; Close Combat Weapon; Bolter; Meltagun (x2); Frag Grenades; Krak Grenades; Rhino
1 Aspiring Champion @ [55] Pts
Bolt Pistol; Power Fist; Bolter; Frag Grenades; Krak Grenades
1 Rhino @ [35] Pts
Twin Linked Bolter; Searchlight; Smoke Launchers
Troops: Chaos Space Marines (11#, 235 Pts)
9 Chaos Space Marines @ 235 Pts
Bolt Pistol; Close Combat Weapon; Bolter; Flamer (x2); Frag Grenades; Krak Grenades; Rhino
1 Rhino @ [35] Pts
Heavy Support: Obliterators (1#, 75 Pts)
1 Obliterators @ 75 Pts
Power Fist; Obliterator Weapons; Fearless; Slow and Purposeful
Total Roster Cost: 750
If you have a theme in mind, that helps.
If now, 750 is small, so you'll want efficient. That means basic chaos marines, maybe with the mark undivided.
Two full size units with pair special weapons, icon undivided, and fistichamp in naked rhino will run you, oh, a bit over 500 points.
Efficient for HQ means daemon prince. Prince with wings will run you not quite 150.
So we're up to about 650, with 100 odd points to spare. For that you could grab a trio of deep striking terminators with a heavy flamer and a fist, a single oblit, a greater daemon (cutting out one of those fists in the process, of course), or the like. You might be able to fit a defiler or vindicator if you shave a few points (maybe 8 man CSM squads with one special?). Maybe a dakkapred.
