Marines Penitent Chaptermaster WIP
DaRedSkull
A while back I decided to make a chapter master for my marines chapter outa bits I had laying around. Now he's just about done and I was hoping to get some feedback.
and yes I realize he is using a chainsword and two powerfists, I saw a model of Rogal Dorn somewhere with the same setup and thought it was cool.
http://img.photobucket.com/albums/v508/Anonamouse12/Chaptermasterwip3.jpg
http://img.photobucket.com/albums/v508/Anonamouse12/Chaptermasterwip2.jpg
http://img.photobucket.com/albums/v508/Anonamouse12/Chaptermasterwip1.jpg
his honor guard are almost done so ill but some pics of them up next.
you know how the sword has thoes bolts on the top of them? and because you used the top of one as the bottem of the back side? well that makes it look a little off, i would recomend doing some more bolts up at the top back, and mabe add a second set at the bottem?
Looks nice enough, the chainsword could use some filling and added detail (the aforementioned bolts).
The BT cross needs some further sanding, GS needs smoothing and... mould lines.....
I always wondered how someone holds something in a glove that has a matter disrupting field surrounding it... or it's switched of while holding something. But then, what's the use of having a big lump of metal when not using it... oh well, it looks ok and that's what counts right?
Beork
Could make a good counts as calgar. Two powerfists and a power weapon. Well chainsword here but, you know maybe the sword's getting polished or something. Good stuff but, as already mentioned, mould lines, filing and gap filling. I'm not a fan of bling but being a Chapter Master I think he needs a bit more. Other than that though, good. :)
