Shrike his Claws
Vissah
I was just reading the codex cause I had nothing else to do when something catched me eye.
The Claws that Shrike field are master crafted so that allows you to reroll one failed to hit.
But then I took a look at the Master Crafted rule and there is says and I quote,
'A master crafted weapon allows the bearer to reroll one failed to hit per player turn when using the WEAPON'
Now if you take a look at the Ravens Talons it says and I quote,
'These are a PAIR of master crafted lightning CLAWS'
So what my question is is that when you use a WEAPON you can reroll one miss but when you use CLAWS do they count as two weapons or just one?
SO if it really counts as two you can reroll two failed to hit.
https://bolterandchainsword.com/topic/160045-shrike-his-claws/
