Base sizes
Technically you should mount the model on whatever base it was supplied with. However, you can mount models on bigger 'scenic' bases provided that:
a the bigger base doesn't change the way models work with the rules,
b you ask your opponents permission for using a different base.
For instance, I mount the techmarine model on a 40mm termy base in my DW army just so it matches with the others. So far no complaints from anyone :).
Cheers
I
https://bolterandchainsword.com/topic/160714-base-sizes/#findComment-1885809
