Custodes Dreadnaught
zarnak21
The main body and legs are made from flymo. I made it in stages cooking each part before adding the next. For example I made the feet - cooked, then the leg, cooked. The same for the body. I then added greenstuff where needed. The shoulder pads are made from plasticard and different sized piping. The elvow joint is a wheel from a leman russ
oops flymo is a lawn mower. LOL
This is what I pulled from wiki:
Fimo is a name for a brand of polymer clay made by Eberhard Faber. According to a 2002 U.S.PIRG report Fimo contains polyvinyl chloride (PVC) mixed with phthalate. Fimo is sold worldwide, and is a German company. Its main U.S. competitor is the American brand Sculpey. The material comes in many different colors; there are many finishes to choose from, and even a softener to use with it because it can be hard to work. It is used for making many things, including jewelry, accessories, and small trinkets. Once shaped, Fimo is baked in a standard or toaster oven for about 30 minutes at 110°C to harden it. Once baked, it can be cut, drilled, painted, sanded, and sliced thin.
