Psycannon Bolts
well, you'll be paying for three shots to ignore invulnerable saves. what are your opponents? anything in power armor will take that save instead.
the ap4 upgrade is useless as a heavy bolter already is
so as stated what is your opponent? armor 4+ or worse with lots of invuilnerable saves, go for it. otherwise a waste of points
I've thought about it a couple of times, but it always seems better to take a PM storm bolter instead. Now I suppose then you could take both, but then that is 20 points ...
no it stays 10 points, vehicle upgrades can only be taken once, the upgrade counts for the entire vehicle (all weapons that can have the bolts get them).
Or maybe after the new IG codex comes out and it becomes Stormtrooper crazy.
could you elaborate? st don't get invulnerable saves do they?
Rumour has it that the Guard stormtroopers will soon be fielding str 3 ap 3 hellguns. AP3 will make a sad day for all power armoured armies.
that i knew but why would psycannon bolts mean any difference for us?
Other than Daemons - if you were going up against a Necrons w/ C'Tan it would be good.
actually that was what i first thought when i bought the codex so many years ago (as soon as it came out), how cool would it be to field a purgation squad and let your opp say bye bye c'tan in the first turn. but then again how many times do you face one?
Even at strength six and three shots a piece bringing down a C'tan in round 1 would be very very difficult. How many psycannons/heavy bolters are you expecting to have shooting at him cause to kill him I guessing you're gonna need high twenties or thirties. wound on a six.... ouch. Sure he gets no save but less than 1/6th of the shots are going to wound anyway. Still its a huge advantage to knock that many points out even in round two.
Eh? I realize that. A PM Stormbolter + Psycannon Bolts = +20 points.
No it isn't, they don't affect the hurricane bolter so you only get the bonus on the pintle-mounted storm bolter. It's even less effective than it is in the normal raider.
Why wouldn`t they get it in the hurricane bolter? It is a `bolt` weapon, is it not?
That would be awesome, but no, under the vehicle upgrade section it says "Storm Bolter or Heavy Bolter." This is different than the wargear entry.
On the flipside, psybolts can't be used for infantry heavy bolters either. Really too bad as that would put Daemon armies in way more of a pickle.
Uncle Mel: psybolts would make a number of bolt weapons AP4 and would therefore ignore ST armor saves. I was thinking in terms of infantry upgrades as well when I made that statement. My bad.
ThePurifier Posted Today, 02:04 AM
That's what the Psycannon is for. Str 6 and an additional Assault 3 profile too.
Its worth noting that Psycannon Bolts do NOT change the weapon Strength to 6. You only get AP 4 and the ability to ignore Inv. Saves.
ah now i get it yes, for stormbolters and such :D
oh, sorry i thought you meant that you pay for the upgrade twice, once for the hb and once for the stormbolter
suppose i look quite stupid now, misinterpreting twice in a topic :ermm:
  • 2 weeks later...
wow people are still alive from that time period? ^_^
Yeah but it costs as much as a GK and means that you lose the str 6 in hth. psycannon bolts let you get the merits of both for less. Now if you could get your entire pagk squad psy bolts for 5 points a piece I would probably take it.
