Brother Tober Posted March 3, 2009 Share Posted March 3, 2009 Is it true that a Drop Pod may not fire in the turn it accesses the battle field? Link to comment https://bolterandchainsword.com/topic/162196-drop-pod-firing/ Share on other sites More sharing options...
Cedric Posted March 3, 2009 Share Posted March 3, 2009 Depends on the Pod... Vanilla Pods are out of luck. Black Templar pods have PotM and can blast away at leisure. Perfect for some much needed pie-plates BT- pods also don't roll for mishaps, due to the sheer awesomness of these guys. The only downside is that they don't enter play on turn one... =/ Link to comment https://bolterandchainsword.com/topic/162196-drop-pod-firing/#findComment-1905905 Share on other sites More sharing options...
Sternguard sergeant McColl Posted March 4, 2009 Share Posted March 4, 2009 C:SM drop pods don't roll for mishap either, unless they scatter off the table. Link to comment https://bolterandchainsword.com/topic/162196-drop-pod-firing/#findComment-1906375 Share on other sites More sharing options...
jubei124 Posted March 4, 2009 Share Posted March 4, 2009 C:SM drop pods don't roll for mishap either, unless they scatter off the table. Right, but at least you get to roll for mishaps, we BT lose the pod and any unit inside if our pods land off the table. :D Link to comment https://bolterandchainsword.com/topic/162196-drop-pod-firing/#findComment-1906394 Share on other sites More sharing options...
Brother Nicolas Posted March 8, 2009 Share Posted March 8, 2009 Why would you lose the pod? The new Deep Strike rules you get the Mishap table also... or is it in your rules that if you go off the table your gone? Link to comment https://bolterandchainsword.com/topic/162196-drop-pod-firing/#findComment-1911551 Share on other sites More sharing options...
jubei124 Posted March 8, 2009 Share Posted March 8, 2009 Why would you lose the pod? The new Deep Strike rules you get the Mishap table also... or is it in your rules that if you go off the table your gone? Our rules for 'drop pod assault' are worded different than those in the C:SM and make no mention of using the deep strike rules when we arive by drop pod. Therefore since we don't use the deep strike rules when arriving by a drop pod assault we cannot use the deep strike mishaps table if the pod was to land off table. Link to comment https://bolterandchainsword.com/topic/162196-drop-pod-firing/#findComment-1911594 Share on other sites More sharing options...
