terminator dedicated Transport
Combo
just a quick question, in constructing a space marine army and it says that one terminator squad in the army can take a land raider as a dedicated transport. Does this land raider still take up a heavy slot, or does it act like other dedicated transports and so not take up a slot at all?
https://bolterandchainsword.com/topic/162376-terminator-dedicated-transport/
thank you!
to clarify a final point the codex says "one terminator squad in the army may select a land raider of any type as a dedicated transport" under the terminator section. Under the Assault terminator Squad section it says "One terminator assault squad in the army may select a land raider of any type as a dedicated transport"
Assuming you follow this exactly a terminator squad does not equal the same as an assault terminator squad. Does this really mean you could get two land raiders as none heavy choices? that seems a bit overkill and I assume this has been retconned?
Just going to pass this over to the Rules Forum for more info....
<Chambers thread moving ammo and blazes away at Rules target>
Spot on, double tap to the chest!
Ahem....I mean over to you Rules guys! :HQ:
Corpus
Well, by that logic, you really should be allowed to have two land raiders as dedicated transports - one for a regular termi squad, and one for an assault squad.
I guess it's just bad wording, but technically it's possible... (although really, that's a minimum of ~440 points per 5 termies + land raider, total 880 points for 12 models without any upgrades, impractical imho)
That is correct, although I don't really see a problem with the wording. If some-one really wants lot of land raiders they can go right ahead....
