Three "Units" in one Drop Pod?
Technically, the answer is yes, but only for the combat squads of a single origin squad.
Combat squading does not happen if you deploy from a drop pod until the squad actually arrives. Because of this, there is only unit 1 and unit 2 (assuming both are held in reserve), so you have no squads 1A and 2A, in addition to the usual rules for transports. Unit 1 and an IC are perfectly fine to deploy all together from a DP and then combat squad though.
a captain with a jump pack is jump infantry and can not ride in a transport.
But you can put 2 ICs and a 10 man squad in a drop pod, then combat squad. The ICs would have to remain joined until they can move out of 2 inches from the squads.
