Ragner Blackmane Posted March 11, 2009 Share Posted March 11, 2009 I need help because I want to give some of my guys a wolf pelt and have some capes, on SM captains, I was gunna turn them into pelts using green stuff. So basically can you give me tips on how to make pelts and turn caes into a pelt. ;) Thanks WL Blackmane Link to comment https://bolterandchainsword.com/topic/162833-wolf-pelts/ Share on other sites More sharing options...
kickme829 Posted March 11, 2009 Share Posted March 11, 2009 use a scuplting knife and make lines to give it a fur look Link to comment https://bolterandchainsword.com/topic/162833-wolf-pelts/#findComment-1913909 Share on other sites More sharing options...
Yeti Posted March 11, 2009 Share Posted March 11, 2009 Take a look in my gallery. The pics of GHs and BCs have some showing pelts on their shoulder pads. http://www.bolterandchainsword.com/index.p...m&album=637 This was done by taking a roughly triangular piece of green stuff and sticking it on the shoulder pad. I then took either a modelling knife or the pointed end of the GW sculpting tool and, using short rapid strokes, created a bunch of shallow cuts in the GS. You can do the same with capes, just cover them with GS and use the same method to create fur. Cuts that are shallower and closer together give a finer texture. I was going for bear fur, so I made gave it a coarser look. Painting is dead simple too. Dark base coat and then a couple of quick drybrushes with lighter colors ... voila! Link to comment https://bolterandchainsword.com/topic/162833-wolf-pelts/#findComment-1913913 Share on other sites More sharing options...
Jonny Wolf Posted March 11, 2009 Share Posted March 11, 2009 Like's been said, use the triangle portion of a hobby knife. For finer hair use a pin or a needle. Piece of advice - use water on the blade/pin when you sculpt. This will stop the steel from sticking to the green stuff. Link to comment https://bolterandchainsword.com/topic/162833-wolf-pelts/#findComment-1913920 Share on other sites More sharing options...
