jeffersonian000 Posted March 13, 2009 Share Posted March 13, 2009 This one threw me: I'm on Army Builder, and it's requiring me to purchase a bolter for the Vet Superior as the upgrade to Vet seems to have robbed her of her weapons. This is this correct? I was under the assumption that an upgraded member of the unit retained their unit weapons unless those weapons are replaced with something else. SJ Link to comment https://bolterandchainsword.com/topic/163052-veteran-sister-superior/ Share on other sites More sharing options...
WarriorFish Posted March 13, 2009 Share Posted March 13, 2009 It's not so much "free" - more of her standard equipment! A Superior - veteran or not - comes with a bolter. You can relace it free of charge with a bolt pistol and close combat weapon. The VSS gets access to the armoury too, so you can by a bolter if you really wanted, which is probably where that comes from. I've not used the Army Builder, so unless you're reading it wrong or something it's incorrect in this case. A model without a weapon is pretty useless :P Link to comment https://bolterandchainsword.com/topic/163052-veteran-sister-superior/#findComment-1916291 Share on other sites More sharing options...
jeffersonian000 Posted March 13, 2009 Author Share Posted March 13, 2009 Woops! I see; the program is smarter than I am, as it does drop the 2pts for the bolter once you select it making the bolter and/or pistol & CCW option effectively free. SJ Link to comment https://bolterandchainsword.com/topic/163052-veteran-sister-superior/#findComment-1916318 Share on other sites More sharing options...
andrewm9 Posted March 13, 2009 Share Posted March 13, 2009 This one threw me: I'm on Army Builder, and it's requiring me to purchase a bolter for the Vet Superior as the upgrade to Vet seems to have robbed her of her weapons. This is this correct? I was under the assumption that an upgraded member of the unit retained their unit weapons unless those weapons are replaced with something else. SJ The 2 point cost is the standard charge I believe for bolters in a WH army. That being said, when you click on the bolter it makes its cost 0 for sister superiors of most varieties. I think the Seraphim Veteran Superior will actually cost 2 points, though I would never give her one. Link to comment https://bolterandchainsword.com/topic/163052-veteran-sister-superior/#findComment-1916324 Share on other sites More sharing options...
W.A.Rorie Posted March 13, 2009 Share Posted March 13, 2009 the bolter point does change to zero when it is selected Link to comment https://bolterandchainsword.com/topic/163052-veteran-sister-superior/#findComment-1916866 Share on other sites More sharing options...
