Weapons of the Primarchs?
gorechild, while big, always seemed to me to be too small for a big burly primarch. We know Angie used that big ole axe that was on the Furious Abyss, though I don't remember what it was called, and the naming convention of Gorechild seems to indicate that somewhere lies a Gorefather. Although I hope that wasn't the name of the axe in that HH book. Therefore, I believe that Angie prolly used daddy axe and lil Kharny had kiddy axe.
Now, Vulkan and his pair of hammers, blacksmith style...that's hardcore.
You are correct, sir. There was a Gorefather. IIRC, Angron was running around with both Gorechild and Gorefather, which is basically Gorechild times ten.
  • 2 weeks later...
Sanguinius - Spear Of Telesto, Blade Encarmine?
Blade Encarmine was what I've understood for about 10 years.
Ferrus Manus - giant wrench
Forgebreaker is correct, as well as his iron hands.
Fulgrim - Fireblade or Laeran Sword
Pre - heresay, Fireblade, Post heresay, Laeran blade.
Jaghatai Kahn - Giant falchion
I believe it was Moonfang, now used by Kor'sarro Khan
Corax - Raven's Talons maybe?
I believe that is correct.
Roboute Guilliman - Sword Of Guilliman or the Gauntlets Of Ultramar (post-Heresy)
Sword of Guilliman
Rogal Dorn
I believe it may be both the Arrow of Dorn SB, carried by Pedro Kantor, and the Fist of Dorn TH, used by Lysander.
Leman Russ - Spear Of Russ, a Frost Blade type sword, a Relic Blade type weapon, Bolt weapon
The Spear of Russ is the right choice.
Night Lord - Lightning Claws probably
Unknown
Lion El'Jonson - Lion Sword
Bingo
Vulkan - Spear Of Vulkan? Gauntlet Of The Forge?
You forgot Kesare's Mantle, and Vulkan's Sigil.
Mortatrion - Manreaper, Lantern
Yep
Angron - giant chain-glaive/pole-axe
Gorefather and Gorechild
Magnus The Red - Chain-khopesh
Unknown
Lorgar - Accursed Crozius
Unknown
Horus - Talon's Of Horus, giant mace
Talon of Horus
Perturabo - Forgebreaker
Not until after Istvaan V.
Otherwise, Unknown.
And yes, I realize that GW retconned a lot of my info. I had to go back to some second edition books to look up and get the info I posted.
The following aren't guesses unless I put a "?" next to them.
http://wh40k.lexicanum.com/mediawiki/images/9/93/Ferrus_Manus.jpg
Jaghatai Kahn - Giant Dao/Tulwar/Shamshir/Falchion/Scimitar (or whatever type of sword it is exactly) which is NOT Moonfang (Moonfang is a Greatsword)
http://wh40k.lexicanum.com/mediawiki/images/thumb/8/85/JaghataiKhan.JPG/300px-JaghataiKhan.JPG
Corax - Raven's Talons maybe? (crafted, but not necessarily used by Corax)
http://i15.photobucket.com/albums/a367/Ieyke/Warhammer%2040k/Guilliman-1.jpg
Rogal Dorn - Bolt weapon(either a Bolter or Bolt Pistol) and Chainblade of some sort(Chainsword or Eviscerator)
http://wh40k.lexicanum.com/mediawiki/images/thumb/c/cf/RogalDorn.jpg/200px-RogalDorn.jpg
http://www.pa-sy.com/hhccg/images/lemanruss.jpghttp://3.bp.blogspot.com/_PWpvlVDLiVI/SQJhq4Fj_QI/AAAAAAAAATs/ei2RGses9hs/s400/leman%20russ.jpghttp://wh40k.lexicanum.com/mediawiki/images/2/2b/LemanRuss.jpg
Night Haunter - Lightning Claws?
Lion El'Jonson - Lion Sword, Lion Helm, Lion's Wrath?
Angron - giant chain-glaive/pole-axe (which I assume to be Gorefather)
http://wh40k.lexicanum.com/mediawiki/images/b/b0/Angron_puzzle.jpg
http://www.thousand-sons.co.uk/images/magnus.jpg
http://wh40k.lexicanum.com/mediawiki/images/0/04/Lorgar.jpg
Horus - Talons Of Horus(pair), giant mace
http://img135.imageshack.us/img135/943/emperorvshorusjq9.jpghttp://farm3.static.flickr.com/2091/2036395028_bc81531aa7_o.jpg
http://wh40k.lexicanum.de/mediawiki/images/thumb/1/1d/Perturabo.JPG/150px-Perturabo.JPG
  • 2 months later...
the emperor gifted Russ with his frostblade, but i forgot the name of it at the moment...
the spear of russ didnt exist till the ragnar series, and was more of a trophy weapon than a weapon of war.
WLK
WLK
i dont think it could of wounded a primarch (magnus) if it was just a trophy
WLK
There is no official line as to whether Black Library fiction counts as official canon.
What weapon did Night Haunter use?
His hands is the most commonly described, though he would use whatever was available to him, like for example the glaive/halberd he took from a slain Phoenix Guard in the short-story: The Dark King. He also used his Psychic Powers there. (yes!)
WLK
well, not a primarch, but magnus isnt exaclty known for his HtH skills is he? ;)
and it was a weapon of war, i stand corrected, but not one highly valued by Russ. in the series its later related that Russ lost that spear multiple times, and eventually left it on Garm.
WLK
Yes. You're the ONLY ONE. Congrats. You have found a way to be unique.:P
Not much beats a giant wrench when it comes to giving a glorious beatdown to some heretic fools.
The lost Primarch Freeman of the Half-Lived used a master-crafted crowbar said to be of epic proportion. I guess that could give the wrench a run for its money. ;)
OK this is bothering me. Angron started out with his HUGE axe(don't know what its called) Then later sometime don't know when he got GOREfather AND GOREchild, witch Khârn later acquired don't know how but it is now in his possession.
All that's known is this:
1. Angron's preferred weapon as a Primarch was the chain-glaive or a pair of chain-axes, reports vary depending on source. More than likely, the chainglaive is the true answer.
2. After his ascension to Daemon Prince, Angron used a monstrous daemon sword of Khorne at Armageddon prior to his banishment back to the Warp.
3. Khârn's given fluff states that he created Gorechild using the teeth of a mica dragon he slew in single combat. Since he's not recorded as having Gorechild at Terra when he supposedly "died", it's assumed he crafted Gorechild after the Heresy. I can't find anything to support the theory that Angron made Gorechild.
I too find the whole wrench thing annoying, I find myself wondering why it was on there. Also, Ferrus used his bare hands, which were made from some unknown substance that enabled them to move like real hands, but be as hard as he needed them to be.
Now, if he found a truly awesome wrench (not that puny thing in the picture) that would be awesome. Until then, it's annoying.
Where are people getting the info that night haunter used his bare hands? There is little to no fluff on him, soo...
I'm a primarch.
I have wings.
I have a sword, it's on FIRE.
I'm Sanguinius.
You're :ed.
I'm Horus...... so much for those wings.
I just finished Night Lord so I'm going with night haunter using the retractable lightning claws. On the same note... they are retractable. So he could have the claws and use his bare hands.
Sanguinius: Spear of Telesto, Blade Encarmine
Rogal Dorn: Bolter, Sword of Dorn (broke it over his knee when couldn't protect emperor, late reforged into Sword of the High Marshals)
Rouboute Guilliman: Gauntlets of Ultramar, Blade of Ultramar
Jaghatai Khan: Never detailed, up to you.
Magnus: Chain Kopesh
Horus: Talon of Horus and power maul
Ferrus Manus: Forgebreaker, later the 'giant wrench' (after Fulgrim nicked Fbreaker)
Fulgrim: Fireblade, Laeran Sword
Leman Russ: Spear of Russ, Freki and Geri (thunderwolves) and his Sword, which was forged from a kraken's tooth.
Vulkan: Presumably Spear of Vulkan-it is an artefact of Vulkan, though it is never described as being specifically his. Background and wording sugest this though.
Perturabo: Forgebreaker, which he later gave to a Warsmith. Warsmith promptly dies and it is returned to Iron Hands. Before he was give Forgebreaker, unknown.
Mortarion: Manreaper, Xenos pattern energy pistol
Corax: Unknown-he never actually used the Raven's Talons
Angron: The chain-axe Brazentooth. Later replaced by Gorefather and Gorechild. Later replaced by runesword. Later replaced by Angron's Black Blade. Gorechild given to Khârn.
Lorgar. Artwork indicates bolter and a type of crozius arcanum.
Hope that has cleared it up.
