The obvious answer is MoS/IoS, so they go at the same time as eldar.
But I don't tailor my list to specific opponents, and my unmarked/IoCG guys usually do pretty well vs eldar, b/c it keeps #'s up, and lets face it, against a good eldar player you are going to lose alot of guys (those guys have no respect for pwr armor :D ).
Things I find useful vs eldar...flamers, hvy bolters, good ol' bolters, rinos used to block LoS, hamper their movement, etc.
https://bolterandchainsword.com/topic/163419-which-mark/#findComment-1920837
But I don't tailor my list to specific opponents, and my unmarked/IoCG guys usually do pretty well vs eldar, b/c it keeps #'s up, and lets face it, against a good eldar player you are going to lose alot of guys (those guys have no respect for pwr armor :sick: ).
Actually in most cases MoS/IoS will be wasted as plenty of eldar units are I6. So i'd go with the regular Icon of Chaos Glory for the reroll. I wouldn't bother with anything other than that as cult troops are better otherwise.
https://bolterandchainsword.com/topic/163419-which-mark/#findComment-1921145
I would say the Mark of Khorne would be the best, Eldar are weak in close combat (though GW wants us to believe otherwise). Having even more attacks their will munch through Eldar units.
Hah someone hasn't told my Eldar army... Most of the time my army is combat based... the Number of World Eater armies I ate in Close combat since 3rd Ed. Hi I'm Going thirst in combat... I'm getting 30+ power weapon attacks (cause I charged), I might need 5's to wound you but in all likely hood your doomed so I can re-roll anyway. Oh I'm a WL you can't hurt me with your standard attacks...(I know Power fists exist).
The thing with Eldar is that most units are specialised for a certain function. To simplify what I mean Striking Scorpions are Anti-horde CC Unit while Howling Banshees are Anti-MEQ/Terminators. So a DP is ok because they find it hard to wound (especially the Howling Banshees, but lets pretend you just have troops). A squad of 10 Chaos Space Marines and a Squad of 10 Generic lesser Daemons. The Eldar player will want the scorpions into the daemons and the Banshees into the Marines what you need to do is try and get it the other way around so that the eldar player isn't getting the most value from his unit and with luck you will win both of the combats... heh if you can get the charge with either of them even better. Against the Eldar its all about seizing the initiative, make them play your game don't play theirs!
But yer Cults units are better than marked units.
https://bolterandchainsword.com/topic/163419-which-mark/#findComment-1921209
Khorne multiplies your strength 4 and going behind their initiative in most fights would be proper. Also not to put too many points into an icon I reinforce the suggestion for khornate icons. It makes your regular marine unit seem scarier to those banshees then usual, because eldar most likely get the charge 'zerkers wont get their furious charge benefits. So you will fight mostly like a zerk unit when charged.
Alternately, I would vie for Nurgle icons, since most of their marine munching ranged and melee weapons can be affected by toughness 5 even if its strength 6, you save a few marines in the long run all the while forcing most of his models to wound you with 6's. (Your entire army is like wounding monstrous*zilla*creatures) Alternately, if he runs with tons of rending, then definately run with tzeentch icons.
I would suggest slaanesh marks for the leaders, so that you can have access to initiative 6 instant kill weaponry, other then that nurgle mark for the leader is best for multi-wound/wound on 4+ (wraithlords/guard).
Thats my version, having played eldar way too much. They will get that charge, your better to take resoloute stuff then the spendy flimsy things. Eldar are made of fast flimsy things superior to youres, so be durable.
https://bolterandchainsword.com/topic/163419-which-mark/#findComment-1923860
