Imperial Guard Codex
Jonny Wolf
Do we use the Imperial Guard Codex for our Leman Russ? (I know we only get the weapons listed in our codex), but for everything else?
Just read this on BoLS:
- Leman Russ special rule: "Lumbering Behemoth" - a Leman Russ that remained stationary or moved up to 6" can fire its turret weapon in addition to any other weapons it may fire - even if the turret weapon is ordnance.
That'd be nice.
https://bolterandchainsword.com/topic/163514-imperial-guard-codex/
OOOOOOOOOOOO.....probibly once a game though, otherwise that seems kinda powerful to me....
Nope, each and every turn.
On the up side ... no more running away from our scouts! :P
Frankly though ... I don't think it'll apply to our version of the Leman Russ. As mentionned we have a complete entry in our codex and unless GW stuns all and redoes the FAQ ... the version in the codex is what you run with. Just ask all the DA players out there!
If it stays in the revised codex though ... I have a feeling we'll be seeing a lot more LREs. With the Lumbering Behemoth and the Heavy 4, twin-linked autocannons we'll have one mega nasty anti-troop platform. Though it'll probably run around 200pts ... all the IG Russ' got a price hike. :(
If were talking about a new codex here theyll have to balance it against the predator. Better armor, slightly higher rate of fire than two predators.... so lets say we double the price of a predator and then add 20pts for saving you a slot? Thats 180, so 200 on the outside is perfectly reasonable as a conservative guess. I really dont think its going to go up.
Everything I've heard of IG says there leman russ' are gonna be 3 - 1 slot. Now if we got that then I would be howling from the roof tops. Doubtful though.
For the IG yes, the Rumor Mill has it going that the Russ will be part of an 0-1 Squadron of 1-3 Russes. However, as we are Space Wolves, we'd get the 1 Russ, since our Codex says 0-1 Leman Russ Exterminator, not 0-1 Leman Russ Squadrons. But knowing GW they'll feth it up and give us a shoddy cut-and-paste from the IG 'dex. Even if they are 200pts a pop... 3 of those bad boys as a single Heavy Support choice. :D :P
For the IG yes, the Rumor Mill has it going that the Russ will be part of an 0-1 Squadron of 1-3 Russes. However, as we are Space Wolves, we'd get the 1 Russ, since our Codex says 0-1 Leman Russ Exterminator, not 0-1 Leman Russ Squadrons. But knowing GW they'll feth it up and give us a shoddy cut-and-paste from the IG 'dex. Even if they are 200pts a pop... 3 of those bad boys as a single Heavy Support choice. ;) :)
I actually meant for when the new dex comes out though I like your idea lmao.
Why? We have predators and land raiders that can move 6" and let loose with all of their lascannons, heavy bolters and autocannons. (Atleast that's my understanding at the moment..)
Ha Ha where did you get that from, 5th means we can move 6 and shoot 1 weapon, and thats it.
SM can move up to 6" and fire one main weapon and all defensive weapons (or in case of the LR and thanks to the PotMS a second main weapon) The IG Leman Russ can move up to 6" and fire all of it´s main guns (battle cannon, hull mouted lascannon and both sponson mounted weapon).
Well the way see it, they need it. the leman russ is supposed to be the workhorse of the IG, and one of the most sturdy tanks around. i know they way i run my guard, they would have a hard time with out the leman russ they have, and i am thinking about adding another (which might change with the new codex). i wouldn't like to see it go up much in points, due mostly to side/rear armor and BS 3. but lumbering for combat speed or 6"+d6" for curising speed works for me.
Dont know if this is old news or not, but I'm signed up to the Games Workshop newletter and they had an article with screenshots and bits from the new IG codex, didn't have time to read it but at least we know that ones finished and out of the way - so hopefully we should be next.
Sorry if this is old news.
