Thaylen Posted March 23, 2009 Share Posted March 23, 2009 If a single unit, for example, 30 boyz in a straight line with maximum coherency (unlikely situation), is assaulted by on both ends by separate units, which way do the orks move when they pile in? Are they required to maintain coherency? Thanks, Thaylen Link to comment https://bolterandchainsword.com/topic/163909-2-vs-1-in-assaults/ Share on other sites More sharing options...
Legatus Posted March 23, 2009 Share Posted March 23, 2009 Maintaining coherency is the most important directive when a unit performs an assault or reaction to an assault, so that ork unit would not be able to move any of it's models. Link to comment https://bolterandchainsword.com/topic/163909-2-vs-1-in-assaults/#findComment-1926842 Share on other sites More sharing options...
Thaylen Posted March 24, 2009 Author Share Posted March 24, 2009 Thanks for the help. -Thaylen Link to comment https://bolterandchainsword.com/topic/163909-2-vs-1-in-assaults/#findComment-1927866 Share on other sites More sharing options...
Hymirl Posted March 24, 2009 Share Posted March 24, 2009 Although if you follow the directives for moving models in assaults/reaction moves (which is to maintain co-herency with a model previously moved) you are able to break co-herency with some, you'd have to go one way or the other though since you'd be stuck to maintaining coherency from the first model you moved an no others. Link to comment https://bolterandchainsword.com/topic/163909-2-vs-1-in-assaults/#findComment-1928199 Share on other sites More sharing options...
