n00b question
Ephemeriis
If I'm adding a Canoness to my army, I have the option of adding a Celestian Retinue.
If I understand correctly, this turns the Canoness + Celestians into a single unit. The Canoness would be unable to leave those Celestians behind.
For no cost difference I can instead add a squad of Celestians. I would be able to join that squad with my Canoness, or leave it and operate her as an IC.
So, my question: What am I missing?
There's got to be some reason why I'd want to add a retinue instead of a separate squad. What is it?
https://bolterandchainsword.com/topic/164004-n00b-question/
also it gives you a Celestian squad without using up an Elite choice, which is REALLY GOOD, as you want as many of those as possible
THIS is the only difference. the canoness doesn't have the retinue special rule so even with a celestian squad she can still be targeted in CC.
https://bolterandchainsword.com/topic/164004-n00b-question/#findComment-1928921
The Canoness is NOT by default an independant character. Her rules state that she becomes one only if her retinue of Celestians dies, or a Celestian Retinue is not bought for her in the first place.
What this means for a Canoness/Palantine with a Celestian bodyguard is that the Canoness will only be worth a kill point if her bodyguard dies also. Until that time, her and the squad are a single unit. This is not to be confused with other IC's that join squads because the Canoness is not an IC to begin with.
https://bolterandchainsword.com/topic/164004-n00b-question/#findComment-1929122
so the typical flying nun of doom build is wrong?
having 'independent character' listed as the first special rule in the codex and a lack of the 'retinue' rule in that same section makes an attached celestian squad the default?
fluff wise she might not be an IC by default, codex wise, she totally is.
https://bolterandchainsword.com/topic/164004-n00b-question/#findComment-1930202
This is how it works fellas;
Flying Nun of Doom: She rides alone or with Seraphim. She is an IC like normal
Canoness+Celestian retinue: She is NOT an IC, she counts as an upgrade character, as per the BRB rules for 'retinues' bought with HQ characters. If the Celestian retinue is killed, she reverts to being an IC next turn.
Hence, the following brutalises most opponents;
Canoness, eviscerator, inferno pistol, Cloak, Book
Priest, eviscerator, power armour, purity seals
VSS, eviscerator, 4 x Celestians, heavy flamer, meltagun
Rhino, extra armour, smokes
(370 points)
You can't attack the Priest or the Canoness directly, and with 'Martyr' turned on the retinue has 3+ invul while the Canoness has a 2+ invul.
Shooting-wise, they're generating two S8 AP2/1 shots for killing transports/softening up TeQ's, and a heavy flamer for softening up infantry. As follow up, on the charge they have 10 x eviscerator attacks (at S8 with 'Hand' turned on) with re-rolls to hit.
https://bolterandchainsword.com/topic/164004-n00b-question/#findComment-1930342
(370 points)
i'm very happy to be wrong about this B)
i totally know what i'm doing next time i face a certain friend of mine haha
https://bolterandchainsword.com/topic/164004-n00b-question/#findComment-1930538
