Terminator's initiative
Not anymore, no. That was an option in earlier edition, but currently, whenever a model has a special close combat weapon it uses it's rules.
And Terminators are Space Marines, so have the Space Marine profile. Assault Terminators can get Thunder Hammers or Lightning Claws, so they may need to strike in initiative order. Characters can get Powerfists together with another special close combat weapon, in which case they could chose which to attack with. Plus, there is allways fleeing from combat, as mentioned above.
Ooopps – old habits die hard I guess :). You're absolutely right there Legatus. To be honest it was a useful if rarely used option.
the answer is also that they may actually loose combat from time to time and will have to make a break-check to see if they run or stay and fight.
Yep. They may need to roll to see if they can break off / get swept - although given they have ATSKNF, they won't be swept, but are instead subject to the "No Retreat" rule.
Pretty nice if your termies successfully fall back after being charged, because they auto-recover, so can unload thier guns and then charge back in (if they want).
Small note they do not necisarily auto recover, they auto pass the test and can take the test even when below 50%, but you still have to obey the rules for when you can recover (aka enemies within 6" or not being in coherency)
