BigJon Posted March 29, 2009 Share Posted March 29, 2009 Legio Astrum Iuguolo (Star Killers) Orgin While the Mechanicus is meticulous with keeping records they are less forth comingwhen asked to produce those records. The creation of the Legio Astrum Iuguolo isthought to be sometime around 745.M41.From the bits collected and piced together the founding started to become clear.The Mechanicus had apparently located a system void of life deep in the Ultima Segmentum that was rich in very rare minerals and ores for mining. The Mechanicusput together a colony fleet and made for the system. Since no Imperial colonies were located theirit was never given a proper name only a binary code that the Mechanicus has kept secret.Upon arriving to the system the Mechanicus found it besieged by a tendril fleet of Hive Fleet Behemoth and will all system resources fighting the body of the fleet theMechanicus were on their own.The arrival of the fleet did not go unnoticed as Tyranid ships started pulling away fromthe main body of the fleet leaving the massive digestion ships to do their work toattack the invaders.Since this was a Mechanicus colony fleet it was very lightly armed and not readyto deal with an enemy fleet of this size.Leading the Mechanicus fleet and set to goveren the new system was a power Arch-Magos named Klawson, such was his rank and position that he had an honor guard made up of Titans from a hand full of LegionsArch-Magos Klawson knew he had to add the Titans firepower to fight offthe Tyranids. The titans were rised to the skin of the ships, cargo bay doors were opened and even outer-hulls were blasted apart to give the titans clearfields of fire.At first the Warlords engaged the larger ships at distance slowing down theTyranid advance but it was not long before the Tyranid ships closed in anddeployed their forces. Reavers and Warhounds engaged the foe with closerange Mega-Bolters and missile launchers and the legions Skirti kept theTyranids from getting far if they did get in the ships.As the titans destroyed more and more Tyranid ships long range scannersdetected more peeling off from the main body of the fleet, more then they could hope to hold off.In a desperate move Arch-Magos Klawson came up with an plan that would eithersave them or kill them all but it was their only chance. As the battle raged around themone of the larger Mechanicus ships broke through the Tyranid ships andmade for the systems Sun.As the ship got closer a Warlord rose from the titan bay armed with a single ship-class Vortex missile mounted to its back. The Warlord launched the missile toward the sun.The Mechanicus ship's started to close ranks bring their shields together for greater strength while the titans added to it with their Void shields as the missile struck.At first the Sun expanded a thousand times its size engulfing the nearby planets and the bulk of the Tyranid fleet with it and when the heat wave swept over theMechanicus ships doing massive damage to vessel and Titans both it also destroyedmost of the close quarter Tyranid vessels. Next, the Suncontracted and formed a tempory Black Hole pulling in any Tyranids ships that were not destroyed in the blast. It took several days for the Mechanicus to bring the bulk of their fleet back into operation status. The titans had lost a third of their machines but without themtheir is no doubt the whole fleet would of fallen to the Tyranid'sArch-Magos Klawson forge-world was gone but the resources he came for wereall around him, with the destruction of the planets in the system the rare minierals would be much easier to get to but would also be harder to defend. Arch-Magos Klawson with some insight saw the need for a Legion to help him carryout his over all plan and put in a request to the Fabercrater General to allow him tokeep his current level of Titans and form a new Legion.Legio: Astrum Iuguolo, defender of the Vortex Fleet.Homeworld Because of the combat action involving the Legion and the Tyranids the colony homeworlds were destroyed, but this was a blessing in the making. Many of the systemsplanets were ripped apart and the Black Hole's gravity pulled many of the brokenworlds into an thick sphere of planetary chucks and asteroids. At the heart of this spherelies the Vortex Fleet, one of the largest Mechanicus fleets ever put together in one place.Its from this fleet the Mechanicus develops Vortex and Void technology, todangerous to be planet side a fleet structure was perfect. Also, the asteroids wererich in raw ore and the Mechanicus set up massive mining and processing ships.Setting apart for the Mechanicus fleet is the fleet of the Astrum Iuguolo, many of theirvessels still bear the scars of that battle with huge sections of their ships still open to space. It is from within these ships the Legion maintain their Titans and conduct the Vortex Fleets mission.Combat Doctrine The Astrum Iuguolo are on a constant state of alert guarding the Mechanicus miningoperations but more importantly the research ships and Vortex production facilities.On rare occasions the Astrum Iuguolo venture out of the asteroid field when ImperialGuard commanders or Space Marine Masters request Vortex support or the destructionof a world its often the Astrum Iuguolo that will escort the weapon to its destinationif not be the very machine that will launch it.The primary function of the Astrum Iuguolo is to escort, deliver and deploy Vortex Missles within a warzone. Depending on the size of the missile or the number requested will determen the make up of the Titan battle group. The Titans of theAstrum Iuguolo while in the field do not fall within the Army Groups chain of commanduntil they have launced their payloads, after which the titans will act in concert withthe Army Groups wishes.One break to this standard is The Astrum Iuguolo have a hate of the Tyranids and will answer the call when issues that Tyranid Bio-Titans are involved in combat. Emperors Hand The "Emperors Hand" was the Warlord that launched the Vortex Missile that saved them and lead to the naming and the path the Legion would take. The Emperors Hand got its name because during thesiege of Terra the Emperor once leaned against the titan, his bloody handprint burned intothe steel of the Warlords foot forever burning bright. After the blast one of the Digestion shipswas blown clear and as it passed the "Emperors Hand" a tentacles reached out and grabbed themight Warlord dragging it from the ship and out into space. It is thought that the "Emperors Hand"still exist as faint signals have been detected coming from deep within current Tyranid fleetcontrolled space. The Astrum Iuguolo await their time to recover their fallen artifact. Organization When the Astrum Iuguolo was founded the Legions strength was 12 Warlord titans.From this number a councle has been made and sitting upon it are the Princeps ofthese 12 Warlords. Their is a 13th seat saved for the Princep of the Emperors Hand.The Mechanicus have a seat as well from the Fleet.The Technology used to interface with the Legions Titans is very different from Legionto Legion. The Astrum Iuguolo princeps have very little in the wayof augmentation, just enough to be able to communicate with Mechanicus and processcombat information, in fact the Titans of the Astrum Iuguolo depend of there Princepsto be in top physical shape, its the Moderati who wear the bulk of the augmentation.Its thought that in post-heresy days this would keep the Mechanicus from having to much of a grip on some of the Titan Legions by keeping the majority of theirprinceps as pure human as possible.The life of a Princeps starts with a Warhound and they work their way up to Warlordwhen they are physically and mentaly able to control them. Heldary When making their way to the colony system the Titans of the Legio Astrum Iuguolo weremarked and painted in parent Legions colors.After the offical founding the councle decided that the Legions machines would bepainted black with silver trim. The heldary of the Princeps would be displayed upon the head of the titanwhile the Moderati's heldary would be displayed upons the shoulder guards. Battle honorsand campain badges would be worn upon the leg armor while kill markings would be found upon the weapons that were credited with the kills.Warhound class titans may repaint their hull armor in camo for the currenttheater of operations since it is their job to scout and defend the Legions Warlords and Reaverswhile they fire their missiles. Link to comment https://bolterandchainsword.com/topic/164527-legio-astrum-iuguolo-star-killers/ Share on other sites More sharing options...
Sons of Horus Posted March 30, 2009 Share Posted March 30, 2009 pretty interesting ;) Link to comment https://bolterandchainsword.com/topic/164527-legio-astrum-iuguolo-star-killers/#findComment-1935086 Share on other sites More sharing options...
Algoroth Posted March 30, 2009 Share Posted March 30, 2009 Fairly well written. Wouldn't the titan legio have been named before departing? Most expeditions are named, and the Mechanicus are meticulous about classification. It would be appropriate that they renamed the legio after the events of the fleet encounter, at which time they would/could have changed their color scheme. It seems incongruous that the entire titan contingent's so new their red paint's still fresh, yet a precious relic such as the Emperor's Hand was along for the ride. Perhaps depict the Arch-Magos as someone of some note, that he would have sufficient pull to bring such a prized god-machine (maybe he was once the princeps of that Warlord?) on the expedition. Link to comment https://bolterandchainsword.com/topic/164527-legio-astrum-iuguolo-star-killers/#findComment-1935137 Share on other sites More sharing options...
BigJon Posted March 30, 2009 Author Share Posted March 30, 2009 Good points Algoroth, I'll tighten it up. The reason for the Older Titans is I envision that the AM can no longer make "new" titans so they just repair/restore and redistribute active ones as needed. The Titans as they were being transported were in Legion formation but just not given a proper name, the AM was going to wait until the AM colony was setup and they had decided to stay before announcing the formal name. I'll work it in. Thanks BigJon Link to comment https://bolterandchainsword.com/topic/164527-legio-astrum-iuguolo-star-killers/#findComment-1935398 Share on other sites More sharing options...
