Chucku Posted April 6, 2009 Share Posted April 6, 2009 When performing an initiative check for Hit & Run do I use the commander's Initiative or the most common Initiative value in the unit? I couldn't find a good answer in the BRB. Thanks! Link to comment https://bolterandchainsword.com/topic/165220-hit-and-run/ Share on other sites More sharing options...
Iron_Chaos_Brute Posted April 6, 2009 Share Posted April 6, 2009 Most common. Link to comment https://bolterandchainsword.com/topic/165220-hit-and-run/#findComment-1944108 Share on other sites More sharing options...
Trekari Posted April 6, 2009 Share Posted April 6, 2009 While you are correct, make sure you cite a page number at the least. Un-documented answers don't serve a legitimate purpose, particularly if the OP has to prove the answer himself during a game. Chucku, page 40, BRB. Outlines the steps and values used for an Initiative test. Link to comment https://bolterandchainsword.com/topic/165220-hit-and-run/#findComment-1944122 Share on other sites More sharing options...
Chucku Posted April 6, 2009 Author Share Posted April 6, 2009 Thanks! I was looking under the Attribute Test section. Link to comment https://bolterandchainsword.com/topic/165220-hit-and-run/#findComment-1944178 Share on other sites More sharing options...
