Characters and KPs
Stargazer
Hi guys
I was just wondering something and wondered if you guys could help me clear this up. We all know that if a brother captain or GM took a retinue then both him and his retinue would = 1KP each
However due to the wording in the rulebook am I correct in thinking that if say you had 1 terminator left and the character and your unit took one wound if you killed the character I believe that your opponent would only get 1 KP for the unit instead of 2
Can someone please tell me whether I'm either completely wrong or whether there is some method in my madness
Many thanks
Stargazer
https://bolterandchainsword.com/topic/165437-characters-and-kps/
This had been topic some time ago. I the end KP are scored for every unit that has been bought. Combat squads are something else... There is a good example in the rule book about the IG command squads, which work the same way the BC/GM squad works.
Hero of the Grey Knights + Guys => 2 KP
However the only reason you get 2 KPs is because the character turns into an independent character when his retinue is killed therefore giving another KP however if you killed the character first surely it wouldn't be an independent character and therefore surely by doing so you would be able to deny a KP
