Primarchs black carapace
Astalon
How did the primarchs first use power armour? did they require black carapace surgery or did they grow up with it already? One would imagine they'd question why they had bits sticking out of their skin even more than their other abilities as it would seem to serve a function they did not know about.
https://bolterandchainsword.com/topic/165858-primarchs-black-carapace/
MAYBE, they don't wear power armour, but instead have some kinda of iron halo built into there normal armour?
There are so many possibilities, personally I like my other one, or this one.
ALSO, if the black carapace is made from one of the Primarchs DNA, does that mean they already have the DNA to wear the armour without edits? xD I mean, maybe they just get the ability in puberty! :P
OMG, Primarch puberty, imagine how annoyed you would have to be looking after an 7-8 foot raging teenager.
It seems that a Primarch's body is dissimilar to that of an Astartes to a huge degree.
The primarch's biology was as far beyond that of a normal Astartes warrior as his own was from a mortal man and Vaddon knew he was out of his depth.Only the Emperor himself had the knowledge to delve into the body of a primarch with confidence, and the enormity of what was occurring was not lost on him.
"We're like children trying to repair a logic engine that's been dropped from orbit. We don't understand even a fraction of what his body is capable of or how it works. I can't even begin to guess what kind of damage it's suffered to have caused this.
However, it may work on similar principles.
"Damn it," cursed Vaddon. "Get me more Larraman serum, his blood won't clot..."
Considering carapace is one of the zygotes the did have it. After all it is not something you would see because it is under the skin.
it is in one of the short stories in tales of heresy that the black carapace is in fact visible in some areas. if you remove the backpack it can be seen according to Sor Talgron.
i always thought it was more similar to Dyp's second idea, are they even wearing power armour?
and as for the black carapace thing, the primarchs were used as a template, so they wouldnt necessarily have all the bits that a marine has due to the extra bits that were probably needed to convert normal humans into marines.
IIRC the black carapace is a non-organic plastic-sheet thingy... Or at least it was RT/2nd ed time. But the primarchs probably didnt have it as it only really became neccesary for MK3 armour (i think - the one with the turnable helmet anyway) as thats when the ad mech began to get better with their neuro link systems enough to use them within power armour... So, the primarchs probably had custom armour built that didnt need a black carapace to function.
ALSO, how does power armour even work with them?
I think it mentions them wearing Terminator armour sometimes, but apparently you have to be small to fit in there, (Since it was joked Abaddon was too big to fit in one) so do they have it custom made with bigger parts?
Yes, of course the primarchs would have undoubtably had custom made armour, weapons, and whatever else.
You dont have to be small to fit into Terminator armour at all, infact its the opposite, Terminator armour is much larger than regualar marine armour, Sergant Pasanius of the Ultramarines had to have converted terminator armour in use with his power armour because he was too large for normal power armour.
It was simply a testimat to Abaddons size to say that he was too big for even Terminator Armour. (he wasnt actulllay too big for it, he was just huge, even for a marine)
The Black Carapace is in fact not necessary to use Power Armour. It only enhances your ability to use it making it like a second layer of skin. This is evident in the fact that Sisters of Battle don't have it and they use their Power Armour perfectly fine.
TDA
I don't think the Primarchs really need to wear it. In "False Gods", there are a few sections where it is discussed how different a Primarch's body is compared to a normal member of the Astartes. I think because of the fact that they are sort of a "pure" form of what a Space Marine should be, then they aren't required to wear the black carapace.
My God, the Black Carapace is the neural uplink tot heir armor. It's what makes them and their armor so in-sync. Sisters don't have it, so their armor is merely powered, a Space Marine's armor is integrated, thats what makes it so superior to other types of power armor. If a Primarch needed to be integrated with his armor, as TDA requires, he would have to have the uplinks installed on his body somewhere. Horus had a tube going up his nose!
Brother-chaplain Astador Posted Today, 02:38 PM
Indeed, Vulkan, Ferrus and Fulgrim have all been revealed to have made some themselves.
Primarchs had custom made armors, and weapons, but given their superior physiology, i'd imagine that they would have certain nerve receptors that normal humans wouldn't have had naturally. i mean they were genetically-manufactured, perhaps this was taken into account during the drawing board stage.
i also like to think of them without power-assisted armor, rather artificer armor that moves more fluidly with them.
While the Black Carapace is directly connected to a marine's nervous system and organs the Black Carapace itself is only compatible with space marine power armour after further surgery.
After several months the carapace will have fully matured and the and the recipient is then fitted with neural sensors and transfusion points cut into the hardened carapace. These artificial 'plug-in' points mesh with systems integral to the powered armour...
Index Astartes Page 5
Since all of the space marine implants are cultured from the genetic material of the Primarchs it seems likely that a Primarch would merely have needed these artifical connections and then he too would have been able to use powered armour in the same way as ordinary space marines.
While the Primarchs have all and more of the abilities of a space marine, as conferred to him by his implants, the Primarchs have these abilities naturally. In that case a Primarch wouldn't probably have a Black Carapace as it appears in ordianry marines but they did/do have the benefits of a Black Carapace just minus all the mechanical parts which get implanted into anyway that wears a form of powered armour.
