Help against chaos armour.
Rezil
So I'm going up against my friend who plays Chaos in a 1500pts battle. Now my mate likes to play shooty (His army are modelled after Iron Warriors) He tends to have
2xVindicators
A couple of squads in Rhino's (Each with at least a las cannon)
His Lord & retinue and a think it's a squad of havoks (not entirley sure, trying to go off of memory)
I'm finding that his Vindicators tend to beast me. I will plug away at them with my land raider and long fangs (Sometimes I get em before they cause serious damage and sometimes not) But if they get to advance far enough they always decimate my troops and are very hazardous to my land raider, meanwhile he sits his army at the back with his multiple heavy weapons and shoots the crap outta me with them too.
My problem is I can't advance as the vidicators wreck my troops, also i'm wondering wether to get rid of my drednought as he always gets targeted and wasted within the first round or two trying to move up field. When I do manage to get within striking range with ym army, his troops I can usually take care of, but his lord will usually run rampant, often annihialting my lord and retinue by himself (Damn chaos lords are hard, I don't like demon weapons!)
So I have provided my army list (Not sure if it's correct as some of the rules I was a little unsure of) in the hopes that someone could suggest a new army setup or tactic that I could try to waste his Chaos force.
I'm a fairly amateur player so I apologise if my information provided isn't amazing.
Cheers
Rez. :D
Lord
Rune Priest: 150
Terminater armour
Combi-plasma
Runic Weapon
Elites
Venerable dreadnought: 155
Power Claw
Assault cannon
Wolf Guard Body Guard
5 x wolf guard terminators :260
3 x lightning claws
2 x thunder hammers
2 x storm shields
Heavy Support
Long Fangs
5 x Long fang pack: 244
1x heavy bolter
1x plasma cannon
1x lascannon
1x multimelta
Land Raider: 250
Troops
Grey Hunters
Wolf Guard Pack leader: 55
Runic armour
Power fist
Plasma pistol
9 x grey hunters : 193
2 x power axe
1 x plasma pistol
1 x melta gun
Blood Claws
Wolf Guard Pack leader: 40
Runic armour
Frost Blade
Plasma Pistol
9x blood claws : 146
1 x power sword
1 x power fist
Total = 1493
https://bolterandchainsword.com/topic/165904-help-against-chaos-armour/
or scouts with melta gun and melta bombs
or maybe a attack bike or speeder with a multi melta
i also use a grey hunter pack kitted out as dread hunters(melta ,krak 2 x power fists wg pl pwer fist melta combi if i got the points0
my main opionent thease days is black legion player that likes shooty lists as well
just remember to close fast they dont like risking them selves with those templates :lol:
I second what has been said about the scouts-give them a power weapon as well though in case they show up late and the tanks are dead. Then you can have them tie up the havoks for a couple of turns. Alternatively, a couple of land speeders with MM are pretty decent against armour, and decently cheap. Just remember to get them within 12" so that you can roll the 2D6 for armour penetration; if his vindi's aren't in cover then they should go smash pretty fast.
WRT to your troops/army list, Wolf Guard Pack Leaders cannot take runic armour OR frostblades. Runic armour is wasted on them anyway, they are part of the squad and can't get targeted. I don't give mine plasma pistols because of the danger of overheat, if you really want them, put them in the squad. I would rather you put your troops in rhinos or drop pods though, it gives them more speed to get across the table so they won't be shot up so bad.
Also, I am counting a RP in termie armour+5 termie WG, which is 12 models for the purposes of fitting into a landraider, which only holds 10. Drop one of the lightning claw termies to make up the difference, and put smoke and extra armour on your ven dread; pop the smoke the first turn he breaks cover and he will live slightly longer. Your Rune Priest is a bit overpriced, a frost blade is cheaper and better, and if you give him a Chooser of the Slain he should get an extra attack with it to boot.
For the long fangs, you seem to have just the models from the boxed set. When you have a chance in the future, get some more heavy weapons so that you can put the HB and MM on the shelf; a LF squad should stick to one general 'type' of weapon, eg, ml/lc or ml/hb, etc. When all 4 are different it is hard to get the best out of the pack; split fire only goes so far. Some more 48" AT wpns would really help in nailing the vindicators. While it is on my mind, remember that if you assault them, you hits are resolved on their rear armour of 10, so if a powerfist gets in striking range, it too can do some real damage. Just remember not to be standing in front of his entire army when the vindicator has been smoked or you will get shot to death.
I would go WS, however a different delivery method thatn OBEL, Put them in a LS Storm w/mm, 4 WS 2PP/MG Give them all MB and make use of the LSS's scout move tom get close enough that if you get turn 1 you will be hitting, possibly from the side, with a MM, 1 MG, 2 PP and then since it's open top possibly assulting 8"with the MB. Expensive but a very verisital unit that can be used for outflanking if you don't get turn 1.
WG Vrox
Two attackbikes with meltaguns... the vindicators advance, or stay still... you move them up low and behind *but not in* cover and then nukem.
Another option is a landspeeder or two with twin multimeltas if you play with larger terrain.
You got to much expensive stuff and that makes for easy targets, better to swamp him with cheaper targets so his shots cost you less
A raider, termys, longfangs AND a dread in a 1500 pt list is very expensive and gives you 2 troop choices, troops win the 5th ED game.
1 tank so all his anti tank goes that way or your dread leaving you slow and exposed
I like using 2 rino's and 2 tanks so he has to make his choice, do i want those tanks shooting me for the next turns or do i want his troops in my line. Put in the scouts to make him move away from the board edge, using your tanks to shield your troop transport. Sure its fun to have all the expensive stuff, but it doesnt work.
