Tacs and Razor backs
Rythlan
You dont even have to intend to split the squad down! If it says you "may" or "can" buy something, but does not list a "when" or "if" type restriction, then go NUTS!
I suppose this is true. My hesitation came from the fact that I would be buying a dedicated transport that the squad could not legally embark.
None the less, I will be going nuts with this rule. Thanks again for the info!
If there's no requirement that a unit be able to embark in their dedicated transport in C:SM (in the unit entries or otherwise) or in the rulebook (which there is not) then yes, you can do it.
Not directly related to razorbacks, but it was noted early on when the new chaos codex came out that that chaos space marines have many units that can potentially be to big for their transports; 11+ member units of CSMs, noise marines, death guard, thousand sons, possessed, and havocs can still all buy a dedicated rhino, and 6+ units of terminators can take a dedicated LR. In fact, the only chaos unit which is restricted from buying a transport if above a certain size is berserkers; they can only take a dedicated rhino if they number 10 or less.
Fluff wise, consider that such units likely use the transport for hauling supplies, as a radio relay, to carry thier wounded, and for other logistics purposes, as well as fire support. Plus, if they loose a few models during the game, you can have them pile in.
