rhinos and storm bolters
kravi
Okay, call me (insert multiple options here) but... Rules question. Rhino comes with a storm bolter, and gets an additional option for a storm bolter.
Where does the default bolter sit (is it the one on the turret?) and where does the extra one sit (if purchased)?
Much obliged.
--Me
https://bolterandchainsword.com/topic/166498-rhinos-and-storm-bolters/
Yeah, frankly you dont need a top hatch in the front if you dont want one.... its up to you. But those two circular holes in the front of the rhino are approximately where a stormbolter goes. Wich one you put them over is rather up to you.... but you can check 20 years of rhinos and thats where theyll be.
ok, so both storm bolters can go on top, one in each hatch (assuming you pay for it)? And then obviously they'll have 360degree arc of fire? (It really was a rules question, less modeling). And if you only have one storm bolter (the default one) then you can put it anywhere - either by itself or with the gunner holding it?
--Me
If you have a single storm bolter only then it can go on either hatch, you can have it crew manned or maching manned, it doesn't matter.. the rues do not differentiate between them...
As for the arc of fire, you can shoot anywhere EXCEPT through the tank, which means you don't quite get 360 arc, its more like 355 arc because you cannot shoot through the other storm bolter, but really how often are you likely to find a situtation where you cannot shoot at a MC, venicle or unit because of the other stormbolter in the way...
