Dreadnoughts and Cover Saves
I did not want to give away too much information so as not to prejudice the answers from the forum readers.
The situation is like this: a SM dreadnought behind a squad of tactical space marines.
I would consider it unlikely the dreadnought was 50% covered, so likely no save.
5th edition is all about True Line of Sight. So unless a crouching Ratling was shooting at the Dreadnought, I do not think it would receive a cover save. Though it is not impossible; you would have to get down and check. If 50% of the model is covered from the firing model's TRUE line of sight, then cover save it is.
It depends on how far the tactical where away from the dreadnought. also if you put 2 marines on top of each other than they are higher than a dreadnought. so if a solid wall of marines with no gaps between them a dreadnought could easily get a cover save.
