Gets hot rule
nope and the wepon isnt destroyed after ether
... wait, what? That's wrong; if you fail your save the gun is destroyed afterwards.
From pg 31, AoBR Booklet:
Roll to hit as normal, except that you must roll to hit even if the target is found to be out of range. For each result of a 1 rolled on its to hit rolls, the firing model suffers a wound (normal saves apply). [emphasis mine]
The firing model suffers a wound. So if you roll to hit and suffer a Gets Hot! result, if you fail your save the plasma gunner dies!
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961358
Oh, I see. How trite. Well, writing it the way Mal does implies that you may fire the plasma gun again, even after failing a Gets Hot! save. Which you cannot. Anyway, I concede the point, the gun is "NOT" destroyed, "EVER", however it may not be fired again after failing a Gets Hot! save.
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961543
How it works, perhaps I didnt explain this very well, and hence got a rather rude and completly uncalled for reply... but never mind that now..
When the weapon 'gets hot' it just over heats and burns the operator, sometimes the burns are severe enough to take him out of commision for a while, sometimes its bad enough to kill him...
And some times he just gets a light tan...
At no point does the weapon itself get destroyed... It continues to function perfectly fine... provided there is anyone left able to operate it.
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961659
I dont think this helps, as an outside observer i fail to see any rudeness. the problem with writing conversations, is its often hard to explain yourselves properly..
Sometimes insults are seen when there was no intent,
Brother Gothard is a good guy, i doubt he was being rude, just he didnt understand your points as you wrote them.
Lets all shake hands and be friends now ;)
GC08
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961679
That's right. In case of a plasma weapon, the weapon 'vents' the overheated steam/goo/whatever which could be potentially dangerous for the weapons bearer. It is just a failsave override system.
In the case of vengeance rounds.. well I cannot easily explain why an exploding shell with an unstable core would not damage a bolter if overheat occurs.
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961684
I was under the impression that if he saved his wound then he could fire with it as normal the following turn but not in the same turn. Is that right?
Yes. My reply was confusing, and I apologize. The weapon may be fired again so long as the model equipped with it is still alive (for ME, 1 wound models are the only models I ever give plasma too, so that was my bad assumption).
Right. The reason I am persisting in this point is because in previous rules editions, when you could allocate wounds around, it was assumed that "special and heavy weapons got picked up by other members of the squad" and so were not lost.
This "provided there is anyone left able to operate it" bit smacks of that, hence why I am persisting that we not leave any room left to wiggle around in.
So, you shoot with a Gets Hot! rule weapon, and you suffer a Gets Hot! special rule (rolling a 1 to hit, or some such). You roll your save, and fail. The model takes a wound, but the weapon is not destroyed. If the model equipped with the Gets Hot! rule weapon dies, then, even though the weapon may still be in perfect condition, the unit loses its ability to fire that special weapon. This is the case for Gets Hot! wounds and regular wounds, of course.
If I am wrong, I would like someone to say specifically that your heavy and special weapons stick around as long as there is at least one model left in the unit. Because it has not been said, but has been hinted at, and hints are evil, nasty things that lead to misunderstandings.
Though I think this is what Mal was saying, that the "provided..." sentence was to refer to not just anyone being left to operate the weapon, but specifically the model the weapon was bought for. Anyway, if this is so, I do apologize.
EDIT: I am not trying to be difficult at all, but it seems to me that either I or someone else in this thread is wrong, and I am getting reaaaaally confused, and I dont like being confused :P ;)
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961763
You do raise a good point..in 5th we allocate wounds, but it would be nice to get a rulebook quote on the exact wording of gets hot...
If it doesnt specifically say the model with the weapon dies then i presume we can shift the wound onto someone else.
However despite not having the rulebook on me i do think it is covered in there, so this may be immaterial, it would be good to be proven either way though.
GC08
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961773
Thats right, not just any tom, dick or harry can use specalised weaponry... hence we are no longer able to have any marine in the squad 'pick it up and keep shooting'... and since there can only be one guy in teh squad armed with that gun, then there is only 1 person in the squad able to operate it...
Thats what my post was refering to.
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961817
GC08
As requested BRB pg 31 "For each result of a 1 rolled on its to hit rolls, the firing medel suggers a wound (normal saves apply)"
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961911
I had a look and P31 of the mini rulebook says that the firing model takes the wound (which they can take a save against.)
I think I have found the definative ruling here.
P25 (mini Rulebook & Big rule book)
"the Player rolls seperately for each model that stands out in game terms. If one of these different modles suffers an unsaved wound, then that specific model must be removed. Note that if a medol carrying a different weapon to the rest of the unit is killed and removed, his squad-members are not allowed to pick up his gun."
I think that one covers it!
Hope this helps.
https://bolterandchainsword.com/topic/166544-gets-hot-rule/#findComment-1961953
