Rhino Wargear and vehicle sizes?
veidin
Hey Chaos Rhinos show twin linked bolter for wargear plus you can add a pintle combi/havoc/etc... where does the twin linked bolter fire from exactly? Is it assumed to be there or should be modeled with one on top?
And secondly where do you find official sizes for vehicles/models? I say people say X vehicle is size 3. What does that mean and where can I find that. I run into a lot of, "Does that block LOS" issues so thank you!
https://bolterandchainsword.com/topic/166682-rhino-wargear-and-vehicle-sizes/
There are two holes on top of the rhino model. You can put your weapons there. As the chaos rhino can only have two weapons, it's very convenient.
There are no official sizes for models, other than what GW produces. Such a thing as "Size 3" no longer exists. All LOS is true, which means you bend down to look from each model's point of view to see what they can see, no abstractions.
If all that is in LOS is the wings, the DP can't be shot. P 16 of the rulebook specifically states you have to have LOS to the body, which is described as head, torso, legs, and arms. It goes on to list things that do NOT count for LOS; wings (and tails) are specifically mentioned as NOT being part of the "body".
