Call of Chaos
  • 3 weeks later...
  • 2 weeks later...
Third update for the Nurgle Horde. This is one complete Plaguebearer squad with command.
I never knew how much detail work there is on Nurgle models. Epidemus took 3 hours to pin and mould all the cracks closed the spare banner I had to pin and use two part epoxy to get it to hold.
This is a copy of what I posted in the Call of Chaos section.
https://bolterandchainsword.com/topic/166691-call-of-chaos/#findComment-1996268
  • 2 weeks later...
Here is an update of the Tally Man I have more done but with two jobs time is limited for updates.
I should have finished pictures by Monday or ealier for this model.
Copy of entry in the other forum, I went darker on this one then Plagubearers but I think it may hinder the look on the feild I am unsure?
Someone at my shop said to use lighter colors to make them standd out, He plays Khorne and Tzeench so very bright models he said mine where too dark what do you all think?
https://bolterandchainsword.com/topic/166691-call-of-chaos/#findComment-2010658
I gave them each a coat of Asuman Blue wash I don't know if I took a picture of that in these pictures. I am goin back to highlight the tops of the model but I never thought about using purple for it. I might try a test model with a mix of purple and blue as a highlight.
I still have to paint flames and teeth I want to see how they turn out first then I will post pictures and see what you think them.
Thanks for the idea I was just going to use a lighter shade of blue but a purple mix might be alot better.
https://bolterandchainsword.com/topic/166691-call-of-chaos/#findComment-2022241
The two units of Flamers are done one unit of 3 one unit of 4. I just took picture of all of them at one time for keeping it simple.
I tried one with purple flames or what ever it is and I could not find a color purple I liked or I should say I could not get a flame I liked it was either to bright, took away from whole paint job. The dark purple hid too much on the dark blue.
Maybe next time I will have more purple shades to work with.
https://bolterandchainsword.com/topic/166691-call-of-chaos/#findComment-2026787
