tarryd Posted April 25, 2009 Share Posted April 25, 2009 After going through my codex I've been trying to figure out if it is possible to split a Tactical squad into Combat squads, and then give each combat squad its own razorback. I Believe this would, while sucking up a lot of points, add some serious fire power to Transport based armies. So far ive been unable to come up with anything that would forbid this, but ive probably missed something. Your thoughts please. Link to comment Share on other sites More sharing options...
Crazy Eight Posted April 25, 2009 Share Posted April 25, 2009 no im affaid u cant as the razor back is bought for the original squad before combat squading the unit therefore only 1 is available .This is how i understand it so i might be wrong Link to comment Share on other sites More sharing options...
greatcrusade08 Posted April 25, 2009 Share Posted April 25, 2009 Crazy eight is right, each unit can have one dedicated transport, so a ten man tactcial squad can buy either a rhino/razorback or drop pod. If it then decides to combat squad, one half can use the transport, whilst the other footslogs.. you cannot buy a second dedicated transport for the same unit, you can however borrow one from another unti (although you cannot set up in it) GC08 Link to comment Share on other sites More sharing options...
Agrab Posted April 27, 2009 Share Posted April 27, 2009 After going through my codex I've been trying to figure out if it is possible to split a Tactical squad into Combat squads, and then give each combat squad its own razorback. I Believe this would, while sucking up a lot of points, add some serious fire power to Transport based armies. So far ive been unable to come up with anything that would forbid this, but ive probably missed something. Your thoughts please. What you can do is buy an extra razor back for a squad and then use it on your split one that said, if they are held in reserve and in the razorback, they can not split... Then, if they are not in (split when enter) then the Razorback might not come on at the same time Link to comment Share on other sites More sharing options...
