Thantoes Posted May 7, 2009 Share Posted May 7, 2009 Ive done a search on this and only turned up threads that pertained to 4th and to if ROB still worked if the IC was in a transport. Bearing in mind that I am at work and dont have the exact wording at hand. Rites of battle essentially says that if Sicarius is in the army and alive, then all units use his leadership for Moral tests. Now in the BRB is says that if a squad takes 25% shooting casualties, looses combat etc then they take a moral test using their leadership value. Now the question is this. If they are now using Sicarius's leadership (who has not been shot/assaulted etc) do you still have to use modifiers?. The wording doesnt really say. To me it would seem to imply that the effected squad would take modifiers to their own leadership value (as they are the ones being nailed) but since they are not using their own leadership it wouldn't count. Any thoughts? Link to comment Share on other sites More sharing options...
Maligoare Posted May 7, 2009 Share Posted May 7, 2009 The only thing which has changed is the effective Ld of the unit, so the same modifiers still apply - Sicarius is not taking the unit's morale test for them, after all! Link to comment Share on other sites More sharing options...
Seahawk Posted May 7, 2009 Share Posted May 7, 2009 It was argued round and around in 4th edition along with the SoB book, but the issue was closed up with new writing. Thus: "If Sicarius is on the table, all other Space Marine units can use his Leadership for any Morale or Pinning tests." "Units that lose a close combat...taking this Morale Check suffer a -1 Ld modifier for each wound their side has lost the combat by." So you start with Sicarius's Ld as a base, then still take negative modifiers as it doesn't say "-1 modifier to their Ld...", just to the one they happen to be using at the time. Maligoare had it right. Link to comment Share on other sites More sharing options...
Steelmage99 Posted May 7, 2009 Share Posted May 7, 2009 The base state of any stat is that it is modifiable. You need a specific rule to change that, like BOL for WH. Anything else makes the game break down. Link to comment Share on other sites More sharing options...
