BlOoD_GoD Posted May 17, 2009 Share Posted May 17, 2009 Ok, being bored i decided to make an objective marker for my CSM. Since they are iron warriors i thought it very appropriate to put weapons and ammo on it, ill post the marker and all that some other time, but for now here are my converted weapons. My VERY chaosy Lascannon: http://i41.tinypic.com/6rrad4.jpg http://i41.tinypic.com/xgfltf.jpg and my Twin-Linked Stalker Pattern Heavy Bolter MK II: http://i40.tinypic.com/2d6r634.jpg http://i42.tinypic.com/24ou9ts.jpg http://i44.tinypic.com/hspf2h.jpg http://i44.tinypic.com/qnk5rq.jpg Note: i do have the MKI version but it was a concept only, if you ask nicely i might post it ;D ~BlOoD_GoD~ P.S. If you want any tutorials on how i did it, just ask and ill post one. Link to comment https://bolterandchainsword.com/topic/168723-coverted-weaponry/ Share on other sites More sharing options...
twistinthunder Posted May 17, 2009 Share Posted May 17, 2009 nice! is that an extended barrel on the heavy bolter? Link to comment https://bolterandchainsword.com/topic/168723-coverted-weaponry/#findComment-1990675 Share on other sites More sharing options...
BlOoD_GoD Posted May 17, 2009 Author Share Posted May 17, 2009 Yeah it is, the heavy bolter is two predator heavy bolter sponsons that have had the part that you clip the ammo feed onto filed down/cut off, then ther ammo fed that is already on it is cut off and turned around, then you cut the end off two predator auto cannon turrets and also cut the end of the heavy bolters off ( but dont cut off the very top part ), glue the two turret ends on and get two of the parts that go on top of a predator sponsona and put them on the very top part of the heavy bolter and on the muzzle, then if you want you can get the handles from the rhino/predator kit and glue then on with a tactical marin scope on the side, but thats if you want it to be manned by a marine. Link to comment https://bolterandchainsword.com/topic/168723-coverted-weaponry/#findComment-1990738 Share on other sites More sharing options...
